HELP NEEDED AGAIN on 1994 40â
04-29-2010, 12:00
I originally had problem with the dash gauge lights not coming on. I replaced
the headlight switch and now the dash gauge lights work but the HEADLIGHT ALERT LIGHT AND BUZZER will not go off even when the engine is running. It goes on as soon as I turn on the running lights or the main headlight switch. I was able to find the buzzer and disconnect one side to stop the buzzing until I find the solution. But that creates a high pitch sound now. Any suggestions to solve this problem? Thanks Nelson Slinman 1994 40WB |
