Free A/C Parts
04-29-2010, 15:47
Free A/C Parts
4.29.2010 - FREE, YOU PAY THE PACKAGING/SHIPPINGââ¬Â¦ Removed Replaced the The three ceiling The three exterior So, 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA |
04-29-2010, 17:43
Free A/C Parts
Curt, Would be interested in knowing what you used as replacement units. Are they more efficient, quieter, have better heat strips. I am asking because I had some Carrier Air V units in another bus, that worked well for cooling, then I added heat strips, and they did not work as expected. There were low and high speeds, with the high almost nullifying the heat coming out. A low and medium speed would have been much better. My units are the original Fridgiking, (for 1977), and may have to replace either one or both this year. Thanks, George Burke 1977 FC31 Charlotte
On Thu, Apr 29, 2010 at 11:47 PM, Curt Sprenger <"curtsprenger@gmail.com"> wrote:
04-29-2010, 23:39
Free A/C Parts
04-30-2010, 01:39
Free A/C Parts
George,
The new A/Cs are the Dometic 13,500 low profile, mechanical ceiling assembly, W/O Heat, Shell White. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Thu, Apr 29, 2010 at 10:43 PM, George Burke <"gnburke@gmail.com"> wrote:
04-30-2010, 01:40
Free A/C Parts
Ernie,
The new A/Cs are the Dometic 13,500 low profile, mechanical ceiling assembly, W/O Heat, Shell White. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Fri, Apr 30, 2010 at 4:39 AM, Ernie Ekberg <"ernietex@yahoo.com"> wrote:
04-30-2010, 01:52
Free A/C Parts
George, others,
The new Dometic low profile 13,500 A/Cs are a bit quieter, no compressor drone, 3 blower settings, push a little more air, no heat strip, Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Thu, Apr 29, 2010 at 10:43 PM, George Burke <"gnburke@gmail.com"> wrote:
04-30-2010, 04:12
Free A/C Parts
Curt,
Can I assume you had to change out all the thermostats also? How much trouble to run the new thermostat cables? Where did you pick up the 12V from? Thanks, Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > George, others, > > The new Dometic low profile 13,500 A/Cs are a bit quieter, no compressor > drone, 3 blower settings, push a little more air, no heat strip, > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > > > On Thu, Apr 29, 2010 at 10:43 PM, George Burke > > > > > > > Curt, Would be interested in knowing what you used as replacement units. > > Are they more efficient, quieter, have better heat strips. I am asking > > because I had some Carrier Air V units in another bus, that worked well for > > cooling, then I added heat strips, and they did not work as expected. > > There were low and high speeds, with the high almost nullifying the heat > > coming out. A low and medium speed would have been much better. My units are > > the original Fridgiking, (for 1977), and may have to replace either one or > > both this year. Thanks, George Burke 1977 FC31 Charlotte > > > > > > On Thu, Apr 29, 2010 at 11:47 PM, Curt Sprenger > > > >> > >> > >> *4.29.2010 - FREE, YOU PAY THE PACKAGING/SHIPPINGââ¬Â¦* > >> > >> *Removed from our ââ¬â¢87 PT38ââ¬Â¦* > >> > >> Replaced the three 13,500 A/C units on our Bird. Two of the A/C units are > >> not worth saving; the third unit has worked fine for 24 years. > >> > >> The three ceiling assemblies, mechanical, are in good shape and include > >> the heat units; I tested the heat units about 5 years ago and they worked > >> then; filters are good. > >> > >> The three exterior covers are in good condition. > >> > >> So, everything is for FREE when you pay for the packaging and shipping. No > >> charge for my time. The units are the low profile Dometic 13,500 units, > >> beige color roof top/ceiling. > >> Curt Sprenger > >> 1987 PT38 8V92 "MacAttack Racing" > >> Anaheim Hills, CA > >> > >> > > > > > |
04-30-2010, 05:15
Free A/C Parts
Mike,
The ceiling assemblies are the mechanical control, no thermostat. Same as the original A/Cs.ÃÂ ÃÂ Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Fri, Apr 30, 2010 at 9:12 AM, mbulriss <"mbulriss@yahoo.com"> wrote:
04-30-2010, 05:24
Free A/C Parts
Hi Mike,
Judy and I will be down to San Diego then back to South Lake Tahoe in a week. I'm interested in the exterior covers. I could drive through to pick them up if no one else has claimed them. Thanks, Paul and Judy Williams 88XXV 40' 8V92 "SeekingOz" South Lake Tahoe, CA -----Original Message-----
From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Fri, Apr 30, 2010 10:15 am Subject: Re: [WanderlodgeForum] Re: Free A/C Parts Mike,
The ceiling assemblies are the mechanical control, no thermostat. Same as the original A/Cs. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Fri, Apr 30, 2010 at 9:12 AM, mbulriss <"mbulriss@yahoo.com"> wrote:
04-30-2010, 05:37
Free A/C Parts
A/C exterior shrouds no longer available.ÃÂ
Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Fri, Apr 30, 2010 at 10:24 AM, <"PRWillms@aol.com"> wrote:
