Powder Balancing
06-20-2005, 13:44
Powder Balancing
What does this mean? Jon
Jon Lechich jipjob@... |
06-20-2005, 14:00
Powder Balancing
Hi Jon,
There are at least two different "powder" materials that are used for balancing of tires. The one I am familiar with is "Equal". I have used it on two coaches so far and I believe it is superior to the Centromatics balancers that I used to have. What they do is put a measured amount in your tire in a package. The package disintegrates in a couple of hundred miles and then you have complete usage. As the tire turns, the powder redistributes itself so as to keep the tire/wheel in balance. I have bee told that is also tends to keep the tread flatter against the road surface giving you better traction. To my knowledge, Equal is only available for the larger truck/bus tires. I have been told that they are working on a formula that will work on the smaller (more turns per mile) tires for cars. The other brand, which I cannot remember the name of right now, claims that theirs will work in any size tire. It sure is nice not having to rebalance every so often... BTW, I have Equal in all eight tires. George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD Jon wrote: > What does this mean? Jon > Jon Lechich > jipjob@... > > > > > > > Yahoo! Groups Links > > > > > > > > > |
06-20-2005, 14:28
Powder Balancing
Does anyone have experience with the power clogging up the tire
stem/valves?? Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, George Lowry wrote: > Hi Jon, > > There are at least two different "powder" materials that are used for > balancing of tires. The one I am familiar with is "Equal". I have > used it on two coaches so far and I believe it is superior to the > Centromatics balancers that I used to have. What they do is put a > measured amount in your tire in a package. The package disintegrates > in a couple of hundred miles and then you have complete usage. As the > tire turns, the powder redistributes itself so as to keep the > tire/wheel in balance. I have bee told that is also tends to keep the > tread flatter against the road surface giving you better traction. > > To my knowledge, Equal is only available for the larger truck/bus > tires. I have been told that they are working on a formula that will > work on the smaller (more turns per mile) tires for cars. The other > brand, which I cannot remember the name of right now, claims that > theirs will work in any size tire. It sure is nice not having to > rebalance every so often... > > BTW, I have Equal in all eight tires. > > George Lowry > '95 WBDA 4203 & GM 4106 (for sale) > Spearfish, SD > > Jon wrote: > > > What does this mean? Jon > > Jon Lechich > > jipjob@Y... > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > |
06-20-2005, 14:36
Powder Balancing
they put a power in the tire that spreads around the tire on the
inside, and balances it out !! seems to work,,, day jax fla pt-40 [Non-text portions of this message have been removed] |
06-20-2005, 14:38
Powder Balancing
it takes a special valve core when you use equal.i have it in my new
toyos.randydupree93wb ----- Original Message ----- From: pattypape To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 20, 2005 10:28 PM Subject: [WanderlodgeForum] Re: Powder Balancing Does anyone have experience with the power clogging up the tire stem/valves?? Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, George Lowry wrote: > Hi Jon, > > There are at least two different "powder" materials that are used for > balancing of tires. The one I am familiar with is "Equal". I have > used it on two coaches so far and I believe it is superior to the > Centromatics balancers that I used to have. What they do is put a > measured amount in your tire in a package. The package disintegrates > in a couple of hundred miles and then you have complete usage. As the > tire turns, the powder redistributes itself so as to keep the > tire/wheel in balance. I have bee told that is also tends to keep the > tread flatter against the road surface giving you better traction. > > To my knowledge, Equal is only available for the larger truck/bus > tires. I have been told that they are working on a formula that will > work on the smaller (more turns per mile) tires for cars. The other > brand, which I cannot remember the name of right now, claims that > theirs will work in any size tire. It sure is nice not having to > rebalance every so often... > > BTW, I have Equal in all eight tires. > > George Lowry > '95 WBDA 4203 & GM 4106 (for sale) > Spearfish, SD > > Jon wrote: > > > What does this mean? Jon > > Jon Lechich > > jipjob@Y... > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-20-2005, 14:38
Powder Balancing
yes,,, i had it happen on the two new front tires i just had
installed,, day,, jax fla 83 pt-40 [Non-text portions of this message have been removed] |
06-20-2005, 15:05
Powder Balancing
I did not know that there was anything different about the valve
core . I thought they just put the colored bands on them to show to the next tire mechanic that the tires infact had equal in them. What would be the difference in the valve core ??? Bob 93pt illinois |
06-20-2005, 15:20
Powder Balancing
The valve core has a filter in it so that the powder cannot get into the
valve stem and cause it to stick. Make sure if you do get equal that you get these valve stems installed. Actually I would not install equal in a RV tire unless you are going to put a lot of miles on the tires. If it sits for any length of time and there is even the slightest amount of water vapor in the tire the equal may clump. Truckers use it and do not have these problems because the tires are constantly moving. On the other hand I have about 40# of Counteract balancing beads a compound which I believe is better for RV use. I am not a dealer and do not intend to sell it although I have the equipment and the product to both inject the beads thru the vavle stem on a installed tire and the bags that are thrown into the casing on new tires. http://www.wheelweights.com/cbb-brochure.pdf#search='counteract%20balancing%20be\ ads' Counteract balancing beads differ from equal in that the composition of the beads and the fact that water moisture does not effect it. In addition counteract balancing beads come in two different compositions one for cars and one for trucks or RVs. The two different beads are engineered for the different tire rebounding characteristics between cars and trucks. I now have it in my steer tires and when I install the new tires will install it in both the steers and the rear duals. tom 1982 FC35 Vernon Center,NY bAt 03:05 AM 6/21/2005 +0000, you wrote: > I did not know that there was anything different about the valve >core . I thought they just put the colored bands on them to show to the >next tire mechanic that the tires infact had equal in them. What would >be the difference in the valve core ??? Bob 93pt illinois > > > > > >Yahoo! Groups Links > > > > |
06-20-2005, 16:34
Powder Balancing
Is this rebounding characteristic that noticeable when you do not have this
material in your tires? Does it make for a smoother ride? Jon Jon Lechich Bremerton Washington Tom Warner The valve core has a filter in it so that the powder cannot get into the valve stem and cause it to stick. Make sure if you do get equal that you get these valve stems installed. Actually I would not install equal in a RV tire unless you are going to put a lot of miles on the tires. If it sits for any length of time and there is even the slightest amount of water vapor in the tire the equal may clump. Truckers use it and do not have these problems because the tires are constantly moving. On the other hand I have about 40# of Counteract balancing beads a compound which I believe is better for RV use. I am not a dealer and do not intend to sell it although I have the equipment and the product to both inject the beads thru the vavle stem on a installed tire and the bags that are thrown into the casing on new tires. http://www.wheelweights.com/cbb-brochure.pdf#search='counteract%20balancing%20be\ ads' Counteract balancing beads differ from equal in that the composition of the beads and the fact that water moisture does not effect it. In addition counteract balancing beads come in two different compositions one for cars and one for trucks or RVs. The two different beads are engineered for the different tire rebounding characteristics between cars and trucks. I now have it in my steer tires and when I install the new tires will install it in both the steers and the rear duals. tom 1982 FC35 Vernon Center,NY bAt 03:05 AM 6/21/2005 +0000, you wrote: > I did not know that there was anything different about the valve >core . I thought they just put the colored bands on them to show to the >next tire mechanic that the tires infact had equal in them. What would >be the difference in the valve core ??? Bob 93pt illinois > > > > > >Yahoo! Groups Links > > > > Yahoo! Groups Links One of my favorite sayings goes! "You never own anything, everything owns you!" --------------------------------- Yahoo! Sports Rekindle the Rivalries. Sign up for Fantasy Football [Non-text portions of this message have been removed] |
06-20-2005, 21:51
Powder Balancing
Jon I can sure feel an out of balance tire and the heavier the tire is the
more you can feel it. It is this out of balance condition that forces the tire down against the pavement and the resulting rebound that causes the balancing beads to be forced to a point opposite to the heavy spot in the tire. The company has found that in the case of an automobile the suspension is designed for a much smooter ride and the beads designed for trucks do not distribute themselves the same way when installed in an automobile. tom 1982 FC35 Vernon Center,NY At 09:34 PM 6/20/2005 -0700, you wrote: >Is this rebounding characteristic that noticeable when you do not have >this material in your tires? Does it make for a smoother ride? Jon >Jon Lechich >Bremerton Washington > >Tom Warner >The valve core has a filter in it so that the powder cannot get into the >valve stem and cause it to stick. Make sure if you do get equal that you >get these valve stems installed. > >Actually I would not install equal in a RV tire unless you are going to put >a lot of miles on the tires. If it sits for any length of time and there is >even the slightest amount of water vapor in the tire the equal may clump. >Truckers use it and do not have these problems because the tires are >constantly moving. > >On the other hand I have about 40# of Counteract balancing beads a compound >which I believe is better for RV use. I am not a dealer and do not intend >to sell it although I have the equipment and the product to both inject the >beads thru the vavle stem on a installed tire and the bags that are thrown >into the casing on new tires. >http://www.wheelweights.com/cbb-brochure.pdf#search='counteract%20balancing%20b\ eads' > >Counteract balancing beads differ from equal in that the composition of the >beads and the fact that water moisture does not effect it. In addition >counteract balancing beads come in two different compositions one for cars >and one for trucks or RVs. The two different beads are engineered for the >different tire rebounding characteristics between cars and trucks. > >I now have it in my steer tires and when I install the new tires will >install it in both the steers and the rear duals. > >tom >1982 FC35 >Vernon Center,NY > > > > >bAt 03:05 AM 6/21/2005 +0000, you wrote: > > I did not know that there was anything different about the valve > >core . I thought they just put the colored bands on them to show to the > >next tire mechanic that the tires infact had equal in them. What would > >be the difference in the valve core ??? Bob 93pt illinois > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > >One of my favorite sayings goes! "You never own anything, everything owns >you!" > > > > > >--------------------------------- >Yahoo! Sports > Rekindle the Rivalries. Sign up for Fantasy Football > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > |
