Air Valve for Vacuum
06-21-2005, 06:48
There is a air valve located on the right front of my 81FC35 that I
believe is used to produce vacuum. There are 4 pressure lines connected to the valve and a diaphragm fitting with three push connections for rubber tubing. The problem is that pressure air is leaking from the push on connection. Does anyone have any experience with this valve? Thanks Charlie Shannon 81FC35 St. Albans, WV |
06-21-2005, 07:42
Its the vacuum control for your cruise control. You might have a loose air
connection on the cruise control under the doghouse. Tom 1982 FC35 Vernon Center,NY At 06:48 PM 6/21/2005 +0000, you wrote: >There is a air valve located on the right front of my 81FC35 that I >believe is used to produce vacuum. There are 4 pressure lines connected >to the valve and a diaphragm fitting with three push connections for >rubber tubing. The problem is that pressure air is leaking from the >push on connection. >Does anyone have any experience with this valve? >Thanks > >Charlie Shannon >81FC35 >St. Albans, WV > > > > > >Yahoo! Groups Links > > > > |
