Kool o matic fan thermostat
05-18-2010, 05:01
I have a 90wb that has a Kool o Matic fan in the galley. The owners manual says
it is controlled by a thermostat in the kitchen but the only one near there is on the opposite side wall between the couch and the table. There is what looks like a ceiling fan switch under the cabinets but it doesn't turn anything on. Is that it and if so is could I get a wiring schematic so I could test it? |
05-18-2010, 05:50
Stephen (?) -
Sounds like my 91. Slide the heat/cool switch under that thermostat to cool to make the galley ceiling fan work. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Stephen" <badersk@...> wrote: > > I have a 90wb that has a Kool o Matic fan in the galley. The owners manual says it is controlled by a thermostat in the kitchen but the only one near there is on the opposite side wall between the couch and the table. > > There is what looks like a ceiling fan switch under the cabinets but it doesn't turn anything on. Is that it and if so is could I get a wiring schematic so I could test it? > |
05-18-2010, 08:22
On my 90wb there are two mid-coach thermostats. One is the center air
conditioner, and the other controls electric heat, propane heat, and the Kool o Matic. Should just be a matter of changing from heat to cool. I swapped that thermostat out for a digital some time ago, but it still works the same way. Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 5/18/2010 at 5:01 PM Stephen wrote: >I have a 90wb that has a Kool o Matic fan in the galley. The owners >manual says it is controlled by a thermostat in the kitchen but the only >one near there is on the opposite side wall between the couch and the >table. > >There is what looks like a ceiling fan switch under the cabinets but it >doesn't turn anything on. Is that it and if so is could I get a wiring >schematic so I could test it? |
05-19-2010, 06:12
Don,
I think maybe mine is missing one. There is only one mid-coach thermostat and it is only for the Air Conditioner. The other switch I refered to has now heat and cool switch. it is simply a reostatic type switch. This coach has been remodeled and I think they may have left it out, because the front toe kick heater doesn't come on either and I can't find a control. Where exactly is the t-stat located on your model? thanks for all the replies Stephen --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > On my 90wb there are two mid-coach thermostats. One is the center air conditioner, and the other controls electric heat, propane heat, and the Kool o Matic. Should just be a matter of changing from heat to cool. I swapped that thermostat out for a digital some time ago, but it still works the same way. > > Don Bradner > 90 PT40 "Blue Thunder" > My location: http://www.bbirdmaps.com/user2.cfm?user=1 > > On 5/18/2010 at 5:01 PM Stephen wrote: > > >I have a 90wb that has a Kool o Matic fan in the galley. The owners > >manual says it is controlled by a thermostat in the kitchen but the only > >one near there is on the opposite side wall between the couch and the > >table. > > > >There is what looks like a ceiling fan switch under the cabinets but it > >doesn't turn anything on. Is that it and if so is could I get a wiring > >schematic so I could test it? > |
05-19-2010, 06:59
Stephen On my 1993 the thermostat in question is
1993 PT-40 From: Don, I think maybe mine is missing one. There is only one mid-coach thermostat and it is only for the Air Conditioner. The other switch I refered to has now heat and cool switch. it is simply a reostatic type switch. This coach has been remodeled and I think they may have left it out, because the front toe kick heater doesn't come on either and I can't find a control. Where exactly is the t-stat located on your model? thanks for all the replies Stephen --- In "WanderlodgeForum%40yahoogroups.com", "Don Bradner" > > On my 90wb there are two mid-coach thermostats. One is the center air conditioner, and the other controls electric heat, propane heat, and the Kool o Matic. Should just be a matter of changing from heat to cool. I swapped that thermostat out for a digital some time ago, but it still works the same way. > > Don Bradner > 90 PT40 "Blue Thunder" > My location: http://www.bbirdmaps.com/user2.cfm?user=1 > > On 5/18/2010 at 5:01 PM Stephen wrote: > > >I have a 90wb that has a Kool o Matic fan in the galley. The owners > >manual says it is controlled by a thermostat in the kitchen but the only > >one near there is on the opposite side wall between the couch and the > >table. > > > >There is what looks like a ceiling fan switch under the cabinets but it > >doesn't turn anything on. Is that it and if so is could I get a wiring > >schematic so I could test it? > |
05-19-2010, 10:28
This picture: http://www.arcatapet.net/travel/images/9...ostats.jpg
shows the original thermostat(s). Under the paper towels is the AC thermostat, and recessed in the partition is the heat/fan t-stat with a switch below it for electric/propane. I've moved the new digital to the other side of that partition, since we typically have toaster and coffee maker under the original location. The dash switches do have to be on for the various toe heaters to work. Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 5/19/2010 at 6:12 PM Stephen wrote: >Don, >I think maybe mine is missing one. There is only one mid-coach thermostat >and it is only for the Air Conditioner. The other switch I refered to has >now heat and cool switch. it is simply a reostatic type switch. This coach >has been remodeled and I think they may have left it out, because the >front toe kick heater doesn't come on either and I can't find a control. >Where exactly is the t-stat located on your model? > >thanks for all the replies >Stephen > >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" >wrote: >> >> On my 90wb there are two mid-coach thermostats. One is the center air >conditioner, and the other controls electric heat, propane heat, and the >Kool o Matic. Should just be a matter of changing from heat to cool. I >swapped that thermostat out for a digital some time ago, but it still >works the same way. >> >> Don Bradner >> 90 PT40 "Blue Thunder" >> My location: http://www.bbirdmaps.com/user2.cfm?user=1 >> >> On 5/18/2010 at 5:01 PM Stephen wrote: >> >> >I have a 90wb that has a Kool o Matic fan in the galley. The owners >> >manual says it is controlled by a thermostat in the kitchen but the only >> >one near there is on the opposite side wall between the couch and the >> >table. >> > >> >There is what looks like a ceiling fan switch under the cabinets but it >> >doesn't turn anything on. Is that it and if so is could I get a wiring >> >schematic so I could test it? >> > > > > >------------------------------------ > >Yahoo! Groups Links > > > |
05-20-2010, 01:28
So I assume the one on the right is the one I am looking for? What is that black
thing beneath it? Thanks again for all your help. --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > This picture: http://www.arcatapet.net/travel/images/9...ostats.jpg shows the original thermostat(s). Under the paper towels is the AC thermostat, and recessed in the partition is the heat/fan t-stat with a switch below it for electric/propane. > > I've moved the new digital to the other side of that partition, since we typically have toaster and coffee maker under the original location. > > The dash switches do have to be on for the various toe heaters to work. > > Don Bradner > 90 PT40 "Blue Thunder" > My location: http://www.bbirdmaps.com/user2.cfm?user=1 > > On 5/19/2010 at 6:12 PM Stephen wrote: > > >Don, > >I think maybe mine is missing one. There is only one mid-coach thermostat > >and it is only for the Air Conditioner. The other switch I refered to has > >now heat and cool switch. it is simply a reostatic type switch. This coach > >has been remodeled and I think they may have left it out, because the > >front toe kick heater doesn't come on either and I can't find a control. > >Where exactly is the t-stat located on your model? > > > >thanks for all the replies > >Stephen > > > >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > >wrote: > >> > >> On my 90wb there are two mid-coach thermostats. One is the center air > >conditioner, and the other controls electric heat, propane heat, and the > >Kool o Matic. Should just be a matter of changing from heat to cool. I > >swapped that thermostat out for a digital some time ago, but it still > >works the same way. > >> > >> Don Bradner > >> 90 PT40 "Blue Thunder" > >> My location: http://www.bbirdmaps.com/user2.cfm?user=1 > >> > >> On 5/18/2010 at 5:01 PM Stephen wrote: > >> > >> >I have a 90wb that has a Kool o Matic fan in the galley. The owners > >> >manual says it is controlled by a thermostat in the kitchen but the only > >> >one near there is on the opposite side wall between the couch and the > >> >table. > >> > > >> >There is what looks like a ceiling fan switch under the cabinets but it > >> >doesn't turn anything on. Is that it and if so is could I get a wiring > >> >schematic so I could test it? > >> > > > > > > > > > >------------------------------------ > > > >Yahoo! Groups Links > > > > > > > |
05-20-2010, 04:40
Yes. The black thing is the electric/propane switch I mentioned.
On 5/20/2010 at 1:28 PM Stephen wrote: >So I assume the one on the right is the one I am looking for? What is >that black thing beneath it? > >Thanks again for all your help. > >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" >wrote: >> >> This picture: >http://www.arcatapet.net/travel/images/9...ostats.jpg shows the >original thermostat(s). Under the paper towels is the AC thermostat, and >recessed in the partition is the heat/fan t-stat with a switch below it >for electric/propane. >> >> I've moved the new digital to the other side of that partition, since we >typically have toaster and coffee maker under the original location. >> >> The dash switches do have to be on for the various toe heaters to work. >> >> Don Bradner >> 90 PT40 "Blue Thunder" >> My location: http://www.bbirdmaps.com/user2.cfm?user=1 >> >> On 5/19/2010 at 6:12 PM Stephen wrote: >> >> >Don, >> >I think maybe mine is missing one. There is only one mid-coach >thermostat >> >and it is only for the Air Conditioner. The other switch I refered to >has >> >now heat and cool switch. it is simply a reostatic type switch. This >coach >> >has been remodeled and I think they may have left it out, because the >> >front toe kick heater doesn't come on either and I can't find a control. >> >Where exactly is the t-stat located on your model? >> > >> >thanks for all the replies >> >Stephen >> > >> >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" >> >wrote: >> >> >> >> On my 90wb there are two mid-coach thermostats. One is the center air >> >conditioner, and the other controls electric heat, propane heat, and the >> >Kool o Matic. Should just be a matter of changing from heat to cool. I >> >swapped that thermostat out for a digital some time ago, but it still >> >works the same way. >> >> >> >> Don Bradner >> >> 90 PT40 "Blue Thunder" >> >> My location: http://www.bbirdmaps.com/user2.cfm?user=1 >> >> >> >> On 5/18/2010 at 5:01 PM Stephen wrote: >> >> >> >> >I have a 90wb that has a Kool o Matic fan in the galley. The owners >> >> >manual says it is controlled by a thermostat in the kitchen but the >only >> >> >one near there is on the opposite side wall between the couch and the >> >> >table. >> >> > >> >> >There is what looks like a ceiling fan switch under the cabinets but >it >> >> >doesn't turn anything on. Is that it and if so is could I get a >wiring >> >> >schematic so I could test it? >> >> >> > >> > >> > >> > >> >------------------------------------ >> > >> >Yahoo! Groups Links >> > >> > >> > >> > > > > >------------------------------------ > >Yahoo! Groups Links > > > |
05-20-2010, 06:31
I think I might have found the wires cut off behind a soffet panel. I have a
green wire and white and a brown, but I don't have the schematic for the circuit in my books. Can anyone provide me with it? --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > Yes. The black thing is the electric/propane switch I mentioned. > > On 5/20/2010 at 1:28 PM Stephen wrote: > > >So I assume the one on the right is the one I am looking for? What is > >that black thing beneath it? > > > >Thanks again for all your help. > > > >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > >wrote: > >> > >> This picture: > >http://www.arcatapet.net/travel/images/9...ostats.jpg shows the > >original thermostat(s). Under the paper towels is the AC thermostat, and > >recessed in the partition is the heat/fan t-stat with a switch below it > >for electric/propane. > >> > >> I've moved the new digital to the other side of that partition, since we > >typically have toaster and coffee maker under the original location. > >> > >> The dash switches do have to be on for the various toe heaters to work. > >> > >> Don Bradner > >> 90 PT40 "Blue Thunder" > >> My location: http://www.bbirdmaps.com/user2.cfm?user=1 > >> > >> On 5/19/2010 at 6:12 PM Stephen wrote: > >> > >> >Don, > >> >I think maybe mine is missing one. There is only one mid-coach > >thermostat > >> >and it is only for the Air Conditioner. The other switch I refered to > >has > >> >now heat and cool switch. it is simply a reostatic type switch. This > >coach > >> >has been remodeled and I think they may have left it out, because the > >> >front toe kick heater doesn't come on either and I can't find a control. > >> >Where exactly is the t-stat located on your model? > >> > > >> >thanks for all the replies > >> >Stephen > >> > > >> >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > >> >wrote: > >> >> > >> >> On my 90wb there are two mid-coach thermostats. One is the center air > >> >conditioner, and the other controls electric heat, propane heat, and the > >> >Kool o Matic. Should just be a matter of changing from heat to cool. I > >> >swapped that thermostat out for a digital some time ago, but it still > >> >works the same way. > >> >> > >> >> Don Bradner > >> >> 90 PT40 "Blue Thunder" > >> >> My location: http://www.bbirdmaps.com/user2.cfm?user=1 > >> >> > >> >> On 5/18/2010 at 5:01 PM Stephen wrote: > >> >> > >> >> >I have a 90wb that has a Kool o Matic fan in the galley. The owners > >> >> >manual says it is controlled by a thermostat in the kitchen but the > >only > >> >> >one near there is on the opposite side wall between the couch and the > >> >> >table. > >> >> > > >> >> >There is what looks like a ceiling fan switch under the cabinets but > >it > >> >> >doesn't turn anything on. Is that it and if so is could I get a > >wiring > >> >> >schematic so I could test it? > >> >> > >> > > >> > > >> > > >> > > >> >------------------------------------ > >> > > >> >Yahoo! Groups Links > >> > > >> > > >> > > >> > > > > > > > > > >------------------------------------ > > > >Yahoo! Groups Links > > > > > > > |
05-20-2010, 08:39
Stephen Those are the ones, I don’t have my coach Steve Quandt PT-40 From: I think I might have found the wires cut off behind a soffet panel. I have a green wire and white and a brown, but I don't have the schematic for the circuit in my books. Can anyone provide me with it? --- In "WanderlodgeForum%40yahoogroups.com", "Don Bradner" > > Yes. The black thing is the electric/propane switch I mentioned. > > On 5/20/2010 at 1:28 PM Stephen wrote: > > >So I assume the one on the right is the one I am looking for? What is > >that black thing beneath it? > > > >Thanks again for all your help. > > > >--- In "WanderlodgeForum%40yahoogroups.com", "Don Bradner" > >wrote: > >> > >> This picture: > >http://www.arcatapet.net/travel/images/9...ostats.jpg shows the > >original thermostat(s). Under the paper towels is the AC thermostat, and > >recessed in the partition is the heat/fan t-stat with a switch below it > >for electric/propane. > >> > >> I've moved the new digital to the other side of that partition, since we > >typically have toaster and coffee maker under the original location. > >> > >> The dash switches do have to be on for the various toe heaters to work. > >> > >> Don Bradner > >> 90 PT40 "Blue Thunder" > >> My location: http://www.bbirdmaps.com/user2.cfm?user=1 > >> > >> On 5/19/2010 at 6:12 PM Stephen wrote: > >> > >> >Don, > >> >I think maybe mine is missing one. There is only one mid-coach > >thermostat > >> >and it is only for the Air Conditioner. The other switch I refered to > >has > >> >now heat and cool switch. it is simply a reostatic type switch. This > >coach > >> >has been remodeled and I think they may have left it out, because the > >> >front toe kick heater doesn't come on either and I can't find a control. > >> >Where exactly is the t-stat located on your model? > >> > > >> >thanks for all the replies > >> >Stephen > >> > > >> >--- In "WanderlodgeForum%40yahoogroups.com", "Don Bradner" > >> >wrote: > >> >> > >> >> On my 90wb there are two mid-coach thermostats. One is the center air > >> >conditioner, and the other controls electric heat, propane heat, and the > >> >Kool o Matic. Should just be a matter of changing from heat to cool. I > >> >swapped that thermostat out for a digital some time ago, but it still > >> >works the same way. > >> >> > >> >> Don Bradner > >> >> 90 PT40 "Blue Thunder" > >> >> My location: http://www.bbirdmaps.com/user2.cfm?user=1 > >> >> > >> >> On 5/18/2010 at 5:01 PM Stephen wrote: > >> >> > >> >> >I have a 90wb that has a Kool o Matic fan in the galley. The owners > >> >> >manual says it is controlled by a thermostat in the kitchen but the > >only > >> >> >one near there is on the opposite side wall between the couch and the > >> >> >table. > >> >> > > >> >> >There is what looks like a ceiling fan switch under the cabinets but > >it > >> >> >doesn't turn anything on. Is that it and if so is could I get a > >wiring > >> >> >schematic so I could test it? > >> >> > >> > > >> > > >> > > >> > > >> >------------------------------------ > >> > > >> >Yahoo! Groups Links > >> > > >> > > >> > > >> > > > > > > > > > >------------------------------------ > > > >Yahoo! Groups Links > > > > > > > |
