Bendix cruise control creeps
05-25-2010, 16:08
Hi All
I have an '86 PT40 with the Bendix cruise. Last season it didn't work and this winter I gave it the once over (everything worked) but now I have a new problem .... it creeps up in speed. It will run fine for miles, and then all of a sudden we're from 65 to 80 ... sometimes going UP hills. Anyone else experienced this ? Is there something I should do to "clear" the memorized speed other than using the brakes ? Marty Spaulding '86 PT40 Kalamazoo |
05-25-2010, 17:48
Marty:
There is a re build kit for the cc5 cylinder, which sticks a little or acts slow. Then you may have an o-ring leaking slightly on the set valves. Is your throttle a little slow acting when you push the peddle? It does not sound like the control unit. In your manual, you will find a trouble shooting guide, but were it mine, I would suspect an o-ring leaking past. Safe travels, Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" Duncan, Oklahoma At 04:08 AM 5/26/2010 +0000, you wrote: >Hi All > >I have an '86 PT40 with the Bendix cruise. Last season it didn't work and >this winter I gave it the once over (everything worked) but now I have a >new problem .... it creeps up in speed. > >It will run fine for miles, and then all of a sudden we're from 65 to 80 >... sometimes going UP hills. > >Anyone else experienced this ? > >Is there something I should do to "clear" the memorized speed other than >using the brakes ? > >Marty Spaulding >'86 PT40 >Kalamazoo > > > |
05-26-2010, 00:08
Hi Marty- I second Ralph's suggestion about a dirty valve on the cruise assembly
or a sticky air throttle cylinder. Once on a trip across Iowa, mine started behaving the same way- but it turned out to be a broken throttle return spring- check those too. The combination of the sticky throttle cylinder and a broken return spring will make for quite a thrill ride! Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "zboy59" > > Hi All > > I have an '86 PT40 with the Bendix cruise. Last season it didn't work and this winter I gave it the once over (everything worked) but now I have a new problem .... it creeps up in speed. > > It will run fine for miles, and then all of a sudden we're from 65 to 80 ... sometimes going UP hills. > > Anyone else experienced this ? > > Is there something I should do to "clear" the memorized speed other than using the brakes ? > > Marty Spaulding > '86 PT40 > Kalamazoo > |
