Water pressure really low on shore water
06-12-2010, 07:05
Hello to everyone,
We are having an issue with our water pressure inside the coach that seems to be getting worse. We are having decreased water pressure when hooked up to shore water. It works fine with the pump on. It always seems to be worse in the morning after it has not been used for several hours. We replaced the water pressure regulator several months ago. Removed it yesterday, tested it and it is working correctly. Checked under the bed and that big filter has already been abandoned. Does anybody have any other suggestions? Any help would be greatly appreciated! Thank you! Robert & Teri Rahn 1988 PT40 |
06-12-2010, 07:26
Did you check the inlet screen on your hose or where the shore water connects? Sometimes it get clogged with algae or sediment and will severely restrict water flow. Jerry 85 PT40 Sent via BlackBerry from T-Mobile From: "chaunceyboyblu" Date: Sat, 12 Jun 2010 19:05:20 -0000 To: Subject: [WanderlodgeForum] Water pressure really low on shore water Hello to everyone, We are having an issue with our water pressure inside the coach that seems to be getting worse. We are having decreased water pressure when hooked up to shore water. It works fine with the pump on. It always seems to be worse in the morning after it has not been used for several hours. We replaced the water pressure regulator several months ago. Removed it yesterday, tested it and it is working correctly. Checked under the bed and that big filter has already been abandoned. Does anybody have any other suggestions? Any help would be greatly appreciated! Thank you! Robert & Teri Rahn 1988 PT40 |
06-19-2010, 00:56
Now this is strange. Regulator is ok, good pressure in the pump, no line
restrictions I presume? Is there a chance the Sporlan valve is leaking filling the tank sending water to the coach and the tank simultaneously while on shore water? --- In WanderlodgeForum@yahoogroups.com, "chaunceyboyblu" wrote: > > Hello to everyone, > > We are having an issue with our water pressure inside the coach that seems to be getting worse. We are having decreased water pressure when hooked up to shore water. It works fine with the pump on. It always seems to be worse in the morning after it has not been used for several hours. We replaced the water pressure regulator several months ago. Removed it yesterday, tested it and it is working correctly. Checked under the bed and that big filter has already been abandoned. Does anybody have any other suggestions? Any help would be greatly appreciated! > > Thank you! > > Robert & Teri Rahn > 1988 PT40 > |
06-19-2010, 01:05
--- In WanderlodgeForum@yahoogroups.com, "Leroy"
> > > Now this is strange. Regulator is ok, good pressure in the pump, no line restrictions I presume? Is there a chance the Sporlan valve is leaking filling the tank sending water to the coach and the tank simultaneously while on shore water? This happen to us while visiting Gettysburg last month. The Sporlan was bleeding water past the valve into the tank. Replaced the Sporlan from Stephen and problem fixed!! Bob Lawrence 84 PT36 Workcamping for the summer in Thomaston, Maine |
