12.5KW Perkins genny fuel return line
06-20-2010, 02:38
I have a 1980 FC35 with the 12.5KW Perkins genny. The fuel return line has a
crack in it. This is the line going across the top of all four injectors and is attached with four banjo bolts. Does anyone have a used one for sale? Thanks in advance Rick in Ohio 419 345 0060 |
06-21-2010, 09:46
Rick,
Rather than trying to find a used one of unknown quality, that return fuel line should still be available from Perkins. You need to find a good Perkins dealer and give them the engine spec number and serial number. The hard part is usually finding a local Perkins dealer. When I had my 83 PT40, I had found a good one here in San Antonio. Go to http://www.perkins.com/northamerica to start the search in your state. Happy hunting. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Rick" > > I have a 1980 FC35 with the 12.5KW Perkins genny. The fuel return line has a crack in it. This is the line going across the top of all four injectors and is attached with four banjo bolts. Does anyone have a used one for sale? Thanks in advance Rick in Ohio 419 345 0060 > |
06-22-2010, 00:05
