water supply to toilet and shower
06-21-2010, 07:37
Can anyone help me with a loss of water pressure to the toilet and the shower on
my 1983 PT35. The water pressure to the front sink is fine only the toilet and shower seam to be affected. Thanks, Jim Elliott 1983 PT 35 |
06-21-2010, 10:55
All systems should be supplied by the same line from the pump or Project Ken Doyle ConServe PO Box 35245 Richmond, VA 23235 direct: 301-908-5735 fax: 804-725-2982 From: Can anyone help me with a loss of water pressure to the toilet and the shower on my 1983 PT35. The water pressure to the front sink is fine only the toilet and shower seam to be affected. Thanks, Jim Elliott 1983 PT 35 |
06-22-2010, 01:16
I was just about to post the identical question to the forum.
We started losing pressure for the hot water to the shower right before we put our 82 PT40 away for the winter last fall. This spring the flow to the shower was reduced to a dribble on the cold and there was no hot water flow. The flow to the sink for both hot and cold water was normal. I assumed that it was the shower fixture and after much effort accompanied by many words of pain, suffering and frustration with small openings and large hands, we managed to replace it only to find that it didn't fix the problem. On our unit the lines to the shower are Tee-d off the ones to the bathroom sink. So I am guessing that the problem has to be in the Tee or the lines that go from under the sink up behind the wall to the shower fixture. On our last trip, the pressure to the toilet seemed to be reduced, but I haven't had time to trace the water line back on it. Because of the lengthy period between my two problems, I am guessing that this must be a separate problem. Anything you find out will be of great interest. Will let you know if I figure out my problem. Dan Carr Columbiana, OH 82 PT40 6V92 Red block --- In WanderlodgeForum@yahoogroups.com, "jaelou2" > > Can anyone help me with a loss of water pressure to the toilet and the shower on my 1983 PT35. The water pressure to the front sink is fine only the toilet and shower seam to be affected. > > Thanks, > > Jim Elliott > 1983 PT 35 > |
