Chassis grounds
06-27-2010, 10:24
Chassis grounds
Hi guys
What is good to put on chassis grounds when you clean them? Is there anything to paint it with or should you just tighten them after they are cleaned. I want to clean up my grounds this summer. Don Spithaler 89 SP 36' Butler, PA |
06-27-2010, 10:42
Chassis grounds
06-27-2010, 21:59
Chassis grounds
Hi Don,
I usually sand the contact surfaces and connector lug and apply a thin film of Dielectric grease. Although the grease does not conduct electricity, mating the two surfaces with a tight connector will push it out of the way and allow the lug and grounding surface to make a good connection. The grease repels moisture and does a nice job of keeping the ground point clean. Don't use too much, or it becomes a "dust magnet". I've used the stuff to waterproof the ends of battery cable lugs and studs over the years with great results. It does not wash off and can only be removed completely with MEK (Methyl Ethyl Ketone). Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "DonS" > > Hi guys > What is good to put on chassis grounds when you clean them? Is there anything to paint it with or should you just tighten them after they are cleaned. I want to clean up my grounds this summer. > Don Spithaler > 89 SP 36' > Butler, PA > |
06-28-2010, 15:07
Chassis grounds
Electrical supply houses have electrically conductive grease that is used when
bolting on heavy wire terminals. This material reduces corrosion and holds up under reasonably high heat applications. This material is particularly used when connecting aluminum conductors. |
06-28-2010, 18:09
Chassis grounds
Here at our Hydro Electric Station, any time that we make connections, whether it be for hot or ground, we use No-oxide.
Bill 1988 40WB XXV "Anniversary Special Edition" (HERS and she not sharing) Terrace, B.C. Canada eh |
06-29-2010, 03:22
Chassis grounds
It goes under the trade name "NOALOX"
-----Original Message-----
From: maumee110 To: WanderlodgeForum@yahoogroups.com Sent: Mon, Jun 28, 2010 10:07 pm Subject: [WanderlodgeForum] Re: Chassis grounds Electrical supply houses have electrically conductive grease that is used when bolting on heavy wire terminals. This material reduces corrosion and holds up under reasonably high heat applications. This material is particularly used when connecting aluminum conductors.
07-01-2010, 05:28
Chassis grounds
07-01-2010, 05:30
Chassis grounds
