Front lights inoperative
06-30-2010, 16:36
There must be a fuse or circuit breaker somewhere - all 8 of my front
fluorescent lights on two separate switches are not working. Strike that - they
do occasionally work, but for the most part they don't. If I turn the switches
on and leave them on, sometimes they will just come on after a random amount of
time.
Any ideas on where to start looking would be greatly appreciated.
-Ryan
1986 PT-40 8V92
06-30-2010, 16:41
Ryan,
I had the same problem with mine and it was the cannon connector. The connector is behind panels in the living cabinet on the curb side. It's a big connector that screws together and has about a dozen wires or so. The connectors become loose or get corroded. You can clean the connector or tighten the female connector side. I did that several times and finally my pin for the lights shorted out. So, I just spliced the wires together and bypassed the connector and haven't had a problem since.
Jerry
85 PT40
Sent: Wed, June 30, 2010 9:36:20 PM
Subject: [WanderlodgeForum] Front lights inoperative
There must be a fuse or circuit breaker somewhere - all 8 of my front fluorescent lights on two separate switches are not working. Strike that - they do occasionally work, but for the most part they don't. If I turn the switches on and leave them on, sometimes they will just come on after a random amount of time.
-Ryan
1986 PT-40 8V92
06-30-2010, 23:42
Ryan, behind the switches are a bunch of wires. I found that I had the same problem and it was one of the butt connectors that had come loose. It was frustrating, but after removing the panel, all is well.
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
Date: Wednesday, June 30, 2010, 11:36 PM
-Ryan
1986 PT-40 8V92
07-02-2010, 04:11
Jerry,
That was it. In fact, it's apparent a previous owner had a problem
with that connector as well, as there were zip-ties wrapped around it
in a failed attempt to hold it together more tightly! LOL... Smile
Thank you for your response. Also, thank you, Ernie, for your response as well.
-Ryan
'86 PT-40 8V92 (with lights, now)
On Wed, Jun 30, 2010 at 9:41 PM, Jerry Burgess wrote:
> Ryan,
problem since.
> Jerry
> 85 PT40
