Rivetnuts
06-22-2005, 12:22
Rivetnuts
sounds like the factory is a blessing to you too !! day jax fla 83
pt-40 In a message dated 6/23/2005 12:19:50 AM Eastern Standard Time, warbucks@... writes: > Subj: RE: [WanderlodgeForum] Re: Rivetnuts > Date:6/23/2005 12:19:50 AM Eastern Standard Time > From:warbucks@... > Reply-to:WanderlodgeForum@yahoogroups.com > To:WanderlodgeForum@yahoogroups.com > Received from Internet: > > > > Has anyone else replaced the rivnuts on their coach and found that the > holes are for hex rivnuts not round ones? I am sure that my coach has the > original rivnuts installed and someone stripped some of them which meant > grinding the heads off and replacing them. What I found was a series of hex > holes and not round ones. There is absolutely no doubt that they were > installed by BB and in fact I verified that when I visited Fort Valley. > When I toured the BB factory the first time I specifically wanted to see > how they installed the rivnuts in the front panels. I knew the newer BB did > not use them but hoped that someone there knew how it was done. After the > tour was over I asked the guide if I could find out how the rivnuts were > installed. Someone went with me and we finally found an employee that not > only knew how to do it, but still had the tools and the rivnuts in his > locker. He had the hydraulic punch to make the hex holes, the air tool to > install the rivnuts and a small quantity of the hex rivnuts. He explained > that BB used the hex rivnuts so they could not turn after installation. > Once they are torqued down they become extremely resistant to turning. You > will strip the inside threads first and that is what happened to mine. > > So when I needed some more hex rivnuts I stopped at parts in Fort Valley to > get some. I had already purchased the tools to install them. Earl Davis > looked at the one hex rivnut I had and told me Bluebird never used them. > But when I insisted the one I had was one I got in the BB factory he > continued looking and finally found a stock of them. > This is what they look like and you can get them from other sources. > http://www.cardinalcomponents.com/fasten...ivnut.htm. > > I bought enough hex rivnuts and stainless steel screws from Earl Davis to > last me for a long time. > > Tom Warner > 1982 FC35 > Vernon Center,NY > > At 08:05 PM 6/22/2005 -0500, you wrote: > >This is about riv-nuts, Not RIV-Nuts. Tim, I don't see how the Dzus > >fasteners would be much help. Unless I am mistaken they would need to > >riveted or bolted to the frame works. It sounds like that might create > some > >problems and a lot of work. I had about half a dozen slipping riv-nuts on > >my coach and was real fortunate in that I was able to get a hold of all of > >them with pliers and get the bolts out without grinding the bolt heads off. > >After I installed new riv-nuts I ran a 1/4"-20 tap into all of the > riv-nuts. > >I also put an anti-seize compound on all the bolts. What a difference. > >You can now run all the bolts in with your fingers and just give the a > quick > >turn with a speed wrench to finish the job. > > > >Chet Geist > >1981 FC33, Austin, Texas > > -----Original Message----- > > From: WanderlodgeForum@yahoogroups.com > >[mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Tim Hannink > > Sent: Wednesday, June 22, 2005 12:05 PM > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Re: Was Bird Sightings (long rant), Now > >Rivetnuts > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > wrote: > > >I've not seen the "hexagonal" rivnuts in a Wanderlodge either, his > > >must be special. Someone might even have installed them in more than > > >one 'Bird, but I've never seen them. > > > > I don't have the hex-type of rivet nut either but was wondering if > > anyone had ever replaced them with a 1/4-turn (or Dzus) fastener? I'm > > sure you could get them in stainless or aluminum and polish them for > > effect and they sure would be easier to remove and less easy to lose > > than the stock 1/4"-20 hex bolts. They also wouldn't sieze up as > > quickly and would be a lot easier on the painted sheet metal that the > > bolts are. > > > > Good luck > > > > Tim Hannink > > Winter Park, FL > > 1981 FC-33SB > > > > > > > > > > > ---------------------------------------------------------------------------- > >-- > > Yahoo! Groups Links > > > > a.. To visit your group on the web, go to: > > http://groups.yahoo.com/group/WanderlodgeForum/ > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > Yahoo! Groups Links > > To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > [Non-text portions of this message have been removed] |
06-22-2005, 13:23
Rivetnuts
holes are for hex rivnuts not round ones? I am sure that my coach has the original rivnuts installed and someone stripped some of them which meant grinding the heads off and replacing them. What I found was a series of hex holes and not round ones. There is absolutely no doubt that they were installed by BB and in fact I verified that when I visited Fort Valley. When I toured the BB factory the first time I specifically wanted to see how they installed the rivnuts in the front panels. I knew the newer BB did not use them but hoped that someone there knew how it was done. After the tour was over I asked the guide if I could find out how the rivnuts were installed. Someone went with me and we finally found an employee that not only knew how to do it, but still had the tools and the rivnuts in his locker. He had the hydraulic punch to make the hex holes, the air tool to install the rivnuts and a small quantity of the hex rivnuts. He explained that BB used the hex rivnuts so they could not turn after installation. Once they are torqued down they become extremely resistant to turning. You will strip the inside threads first and that is what happened to mine. So when I needed some more hex rivnuts I stopped at parts in Fort Valley to get some. I had already purchased the tools to install them. Earl Davis looked at the one hex rivnut I had and told me Bluebird never used them. But when I insisted the one I had was one I got in the BB factory he continued looking and finally found a stock of them. This is what they look like and you can get them from other sources. http://www.cardinalcomponents.com/fasten...ivnut.htm. I bought enough hex rivnuts and stainless steel screws from Earl Davis to last me for a long time. Tom Warner 1982 FC35 Vernon Center,NY At 08:05 PM 6/22/2005 -0500, you wrote: >This is about riv-nuts, Not RIV-Nuts. Tim, I don't see how the Dzus >fasteners would be much help. Unless I am mistaken they would need to >riveted or bolted to the frame works. It sounds like that might create some >problems and a lot of work. I had about half a dozen slipping riv-nuts on >my coach and was real fortunate in that I was able to get a hold of all of >them with pliers and get the bolts out without grinding the bolt heads off. >After I installed new riv-nuts I ran a 1/4"-20 tap into all of the riv-nuts. >I also put an anti-seize compound on all the bolts. What a difference. >You can now run all the bolts in with your fingers and just give the a quick >turn with a speed wrench to finish the job. > >Chet Geist >1981 FC33, Austin, Texas > -----Original Message----- > From: WanderlodgeForum@yahoogroups.com >[mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Tim Hannink > Sent: Wednesday, June 22, 2005 12:05 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Was Bird Sightings (long rant), Now >Rivetnuts > > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > wrote: > > I've not seen the "hexagonal" rivnuts in a Wanderlodge either, his > > must be special. Someone might even have installed them in more than > > one 'Bird, but I've never seen them. > > I don't have the hex-type of rivet nut either but was wondering if > anyone had ever replaced them with a 1/4-turn (or Dzus) fastener? I'm > sure you could get them in stainless or aluminum and polish them for > effect and they sure would be easier to remove and less easy to lose > than the stock 1/4"-20 hex bolts. They also wouldn't sieze up as > quickly and would be a lot easier on the painted sheet metal that the > bolts are. > > Good luck > > Tim Hannink > Winter Park, FL > 1981 FC-33SB > > > > >---------------------------------------------------------------------------- >-- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > |
06-22-2005, 14:23
Rivetnuts
I've been happy with anti-seize on the threads, and not over-
tightening them. The problem I have is paint, touching the things up every time I open a panel. I believe that the original bolts are stainless-steel, so don't really need paint, but I like the painted look. Stainless-steel screws look okay too. Mike H has used rubber-backed metal washers on his freshly painted coach, keeps from marring the paint on the coach panels. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "Chet Geist" wrote: > This is about riv-nuts, Not RIV-Nuts. Tim, I don't see how the Dzus > fasteners would be much help. Unless I am mistaken they would need to > riveted or bolted to the frame works. It sounds like that might create some > problems and a lot of work. I had about half a dozen slipping riv- nuts on > my coach and was real fortunate in that I was able to get a hold of all of > them with pliers and get the bolts out without grinding the bolt heads off. > After I installed new riv-nuts I ran a 1/4"-20 tap into all of the riv-nuts. > I also put an anti-seize compound on all the bolts. What a difference. > You can now run all the bolts in with your fingers and just give the a quick > turn with a speed wrench to finish the job. > > Chet Geist > 1981 FC33, Austin, Texas > -----Original Message----- > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Tim Hannink > Sent: Wednesday, June 22, 2005 12:05 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Was Bird Sightings (long rant), Now > Rivetnuts > > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > wrote: > > I've not seen the "hexagonal" rivnuts in a Wanderlodge either, his > > must be special. Someone might even have installed them in more than > > one 'Bird, but I've never seen them. > > I don't have the hex-type of rivet nut either but was wondering if > anyone had ever replaced them with a 1/4-turn (or Dzus) fastener? I'm > sure you could get them in stainless or aluminum and polish them for > effect and they sure would be easier to remove and less easy to lose > than the stock 1/4"-20 hex bolts. They also wouldn't sieze up as > quickly and would be a lot easier on the painted sheet metal that the > bolts are. > > Good luck > > Tim Hannink > Winter Park, FL > 1981 FC-33SB |
06-22-2005, 16:58
Rivetnuts
Dunno 'bout what type they are in mine, but three weeks ago broke
off one trying to get it out trying to inspect the radiator. They are stainless and look great, yet have the lame phillips heads. I am replacing them with allen head versions. When I put mine back in, I did Anti Sieze everyone except the broken, which is still in there. I will also be tapping each hole to make sure that they don't give me any more fits. To Steven , I really liked the Neptunian language you write. WOW! I was crackin' up so hard dude! Seriously. That was fun. Tony Pawley Ballard, Wash. '79 FC33 3208T --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > Has anyone else replaced the rivnuts on their coach and found that the > holes are for hex rivnuts not round ones? |
06-22-2005, 22:40
Rivetnuts
Great idea. I never would have thought of it. Thanks.....
John Stiles 1980 33FC "My Navion" --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" wrote: > > Mike H has used rubber-backed metal washers on his freshly painted > coach, keeps from marring the paint on the coach panels. > > - Jeff Miller > |
