bosch relay minimum voltage
07-12-2010, 04:44
Greetings All:
What is the minimum voltage needed to reliably activate the bosch relays used in the headlight and taillight mods? I need to boost the voltage to the trailer receptacle, but want to avoid running a new wire loom from the front of my PT. Thanks-- M.R.Kane 1987 PT40 currently near Terrell, TX |
07-12-2010, 06:25
MR,
Activate voltage is about 8 volts for a Bosch relay. The drop out voltage is 1 to 5 volts. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Mon, Jul 12, 2010 at 9:44 AM, mrkane1952 <"mrkane@isp.com"> wrote:
07-12-2010, 06:36
MR,
A handy tool...Regulated Switching Power DC/DC Converter #PCT DC-292. I purchased it at powerstream.com .Use it to test a Bosch relay activation & deactivation. Check it out on the net. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Mon, Jul 12, 2010 at 11:25 AM, Curt Sprenger <"curtsprenger@gmail.com"> wrote:
MR, |
