Leaf springs on older Birds
07-31-2010, 09:49
Fred,
Not sure. Here is there info.
Warren Spring & Mfg Co
9527 S Alameda St
Los Angeles, CA,
90002
323-566-5107
Curt Sprenger
Anaheim Hills, CA
On Sat, Jul 31, 2010 at 12:36 PM, Fred Hulse <"fhulse@wildblue.net"> wrote:
Is Warren Spring in downtown LA still doing business?
They were the place some years ago.
Fred Hulse
Side Door 97
07-31-2010, 09:52
I just relised I didn't state that I was looking for front springs.
Roger
--- In WanderlodgeForum@yahoogroups.com, George Burke wrote:
> Ok, Roger/Ralph, Here is the only info that I have found on springs for a
> 1977 FC 31 with a Ford gas engine. "From BlueBird" , Springs used on
> BlueBird chassis are manufactured to our specifications by well known
> manufacturers of automotive type springs. Under Rear Spring Group (Forward
> Control) is Part No. 0350686 Spring 3 X 52 X 11 Leaf . Application All Qty 2
> . A couple pins are listed as being made by Ford, and some nuts by Bowman
> Product Co. Roger, maybe someone with knowledge of a former BB mechanic from
> the factory that is working for another RV company could help you, or check
> with a good spring company, with the above specs. on the whole leaf spring
> assy. Good Luck, George Burke 1977 FC 31 Charlotte
> On Sat, Jul 31, 2010 at 2:08 PM, Fullenwider wrote:
> > Hi George:
> > Thank you for getting back and sorry it has taken a while to reply. We have
> > a new Birder (Rodger)in the LA Cal area with a new to him '75 31 footer with
> > some broken leaf springs and no numbers or where to go to get them. Please
> > see msg # 48163
> > Curt/Phil here is a, new to him, Birder that needs info on the Left Coast
> > Bird group.
> > George Burke wrote:
> > > Hello Ralph, Don't know what kind of info that you are looking for, but I
> > > have a 1977 Bird with a Ford 534CI gas engine. I vaugely remember a
> > recent
> > > post by someone saying that the rear end on a Bird that he was
> > > looking seemed to be either forward or backward of where he thought it
> > > should be. With that, I can be of no help. Every truck,bus,RV, etc,
> > > including mine, that I have ever seen, the wheels,rear end and all other
> > > things seemed to all be centered within the wheel well. Other than that,
> > > FIRE AWAY. George Burke 1977 FC31 Charlotte
> > > On Thu, Jul 29, 2010 at 12:13 PM, Ralph L. Fullenwider wrote:
> > > > Hi Guys and Gals:
> > > > Anyone have any info on leaf springs used on '78 gas Birds? Had a call
> > > > today asking me and I just don't have that info.
> > > > Thanks
> > > > Safe travels,
> > > > Ralph and Charolette Fullenwider
> > > > "84FC35 "Ruff Diamond"
> > > > Duncan, Oklahoma
07-31-2010, 10:15
Curt
That is the place, thats for the memory,
I recall phoning them for something and Louie Warren would answer the phone and talk to you as if he knew you from way back.
Really nice place to do business "back in the day"
Fred Hulse
MID DOOR 97
07-31-2010, 15:44
You are lucky Roger. The front axle is the same. Part # 0350686 Spring 3"X52"X11 leaf. I just saw that front and rear axles on Birds back then were made Rockwell, which is now Arvin Meritor, for a little more info
On Sat, Jul 31, 2010 at 5:45 PM, idkgfy <"idkgfy@yahoo.com"> wrote:
Thank you George are those front spings or rear spings, in your post it sez rear spring group.
Roger
> > Hi George:
> > see msg # 48163
> > Bird group.
> > --- In "WanderlodgeForum%40yahoogroups.com"40yahoogroups.com>,
> > recent
> > > > Hi Guys and Gals:
> > > > Thanks
> > > > Safe travels,
> > > > Duncan, Oklahoma
08-01-2010, 04:15
Thank you George Wow I'm surprised I would of thought the rear spings were
16,000 or 18,000 lbs. This is good to know. All of our trucks have Meritor axels
and brakes, we have more attrition with the newer stuff the we do with the older
Rockwell stuff. I'm a Heavy Duty Equipment Mechanic for the LAFD.
Roger
> > rear spring group.
> > Roger
> > (Forward
> > Qty 2
> > from
> > check
> > spring
> > > > Hi George:
> > have
> > with
> > Please
> > > > see msg # 48163
> > Coast
> > > > Bird group.
> > > > --- In
> > but I
> > > > recent
> > it
> > other
> > that,
> > > > > On Thu, Jul 29, 2010 at 12:13 PM, Ralph L. Fullenwider > > >wrote:
> > > > > > Hi Guys and Gals:
> > call
> > > > > > Thanks
> > > > > > Safe travels,
> > > > > > Duncan, Oklahoma
08-01-2010, 05:03
Roger,
Do you know Carroll Hieland. He just retired from the Los Angeles Fire Dept.; good friend and neighbor.
Curt Sprenger
Anaheim Hills, CA
On Sun, Aug 1, 2010 at 9:15 AM, idkgfy <"idkgfy@yahoo.com"> wrote:
Thank you George Wow I'm surprised I would of thought the rear spings were 16,000 or 18,000 lbs. This is good to know. All of our trucks have Meritor axels and brakes, we have more attrition with the newer stuff the we do with the older Rockwell stuff. I'm a Heavy Duty Equipment Mechanic for the LAFD.
Roger
> > rear spring group.
> > Roger
> > (Forward
> > Qty 2
> > from
> > check
> > spring
> > > > Hi George:
> > have
> > with
> > Please
> > > > see msg # 48163
> > Coast
> > > > Bird group.
> > 40yahoogroups.com>,
> > but I
> > > > recent
> > it
> > other
> > that,
> > >wrote:
> > > > > > Hi Guys and Gals:
> > call
> > > > > > Thanks
> > > > > > Safe travels,
> > > > > > Duncan, Oklahoma
08-01-2010, 09:11
Glad to help Roger. I used to be  Heavy equipment mech. in the USAF,(late 60's), and now have forgotten more than I will ever know. My rear is the L155, which Arvin Meritor said that I should move up to a 19,000 to 21,000 lb. rear with a gear ratio that I liked, as they no longer make the L155, (considered a light duty rear), and they still mfg. and support the latter rears. A previous owner from the Tn. mountains had the rear changed from a 4.63 to a 5.29. I would like to get a 4:10/4.11 gear but have not found it. While BB was still open, I found out that they never used anything higher than the 4.63 in the FC's or the school buses, as they wanted to get them moving, and gas wasn't that expensive back then. BTW, I think that the L155 rear was rated at15,500 lb. Good Luck, George Burke 1977 FC 31 Charlotte
Roger
> > rear spring group.
> > Roger
> > (Forward
> > Qty 2
> > from
> > check
> > spring
> > > > Hi George:
> > have
> > with
> > Please
> > > > see msg # 48163
> > Coast
> > > > Bird group.
> > 40yahoogroups.com>,
> > but I
> > > > recent
> > it
> > other
> > that,
> > > > > > Hi Guys and Gals:
> > call
> > > > > > Thanks
> > > > > > Safe travels,
> > > > > > Duncan, Oklahoma
08-01-2010, 10:16
George- were you ever stationed at Reese AFB, Lubbock, Tx? I was there from 67-71.
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Sun, 8/1/10, George Burke wrote:
Subject: Re: [WanderlodgeForum] Re: Leaf springs on older Birds
Date: Sunday, August 1, 2010, 4:11 PM
Glad to help Roger. I used to be Heavy equipment mech. in the USAF,(late 60's), and now have forgotten more than I will ever know. My rear is the L155, which Arvin Meritor said that I should move up to a 19,000 to 21,000 lb. rear with a gear ratio that I liked, as they no longer make the L155, (considered a light duty rear), and they still mfg. and support the latter rears.A previous owner from the Tn. mountains had the rear changed from a 4.63 to a 5.29. I would like to get a 4:10/4.11 gear but have not found it. While BB was still open, I found out that they never used anything higher than the 4.63 in the FC's or the school buses, as they wanted to get them moving, and gas wasn't that expensive back then. BTW, I think that the L155 rear was rated at15,500 lb. Good Luck, George Burke 1977 FC 31 Charlotte
Roger
> > rear spring group.
> > Roger
> > --- In WanderlodgeForum@ yahoogroups. com40yahoogroups. com>,
> > (Forward
> > Qty 2
> > from
> > check
> > spring
> > > > Hi George:
> > have
> > with
them.
> > Please
> > > > see msg # 48163
> > Coast
> > > > Bird group.
> > but I
> > > > recent
> > it
> > other
> > that,
> > > > > Hi Guys and Gals:
> > call
> > > > > > Thanks
> > > > > > Safe travels,
> > > > > > Duncan, Oklahoma
08-01-2010, 12:06
Now Ernie, You know that back then they usually sent the Yanks down south, and the Rebs up north. I was stationed at Westover AFB from May-67 to Mar-70, (had a TDY on Project Arclite from Aug-68 to Jan-69). Left Ma. for Alaska in Mar-70, got out in Feb-71. The only time that I saw any warm weather was the  6 mos. in Guam. Decided to get out after the Alaska thing because most Heavy Equip Mechs spent a lot of time in cold weather, and (as my track record wasn't looking so good) , I said adios. But to answer part of your question, I would have loved to have spent more time in Tx. Regards, George Burke 1977 FC 31 Charlotte
83PT40
Wanderlodge
Roger
> > rear spring group.
> > Roger
> > (Forward
> > Qty 2
> > from
> > check
> > spring
> > > > Hi George:
> > have
> > with
> > Please
> > > > see msg # 48163
> > Coast
> > > > Bird group.
> > but I
> > > > recent
> > it
> > other
> > that,
> > > > > > Hi Guys and Gals:
> > call
> > > > > > Thanks
> > > > > > Safe travels,
> > > > > > Duncan, Oklahoma
08-01-2010, 12:38
George, you are correct in that USAF sent us Yanks- grew up in Mass south. Actually they sent me to Amarillo for basic. Talk about a culture/ environment shock. They were going to send me to Denver close to my discharge. Thanks, but no.
83PT40
Wanderlodge
Date: Sunday, August 1, 2010, 7:06 PM
Now Ernie, You know that back then they usually sent the Yanks down south, and the Rebs up north. I was stationed at Westover AFB from May-67 to Mar-70, (had a TDY on Project Arclite from Aug-68 to Jan-69). Left Ma. for Alaska in Mar-70, got out in Feb-71. The only time that I saw any warm weather was the 6 mos. in Guam. Decided to get out after the Alaska thing because mostHeavy Equip Mechs spent a lot of time in cold weather, and (as my track record wasn't looking so good) , I said adios. But to answer part of your question, I would have loved to have spent more time in Tx. Regards, George Burke 1977 FC 31 Charlotte
83PT40
Wanderlodge
Roger
> > rear spring group.
> > Roger
> > (Forward
> > Qty 2
> > > Product Co. Roger,
> > from
> > check
> > spring
> > > > Hi George:
> > have
> > with
> > Please
> > > > see msg # 48163
> > Coast
> > > > Bird group.
> > but I
> > > > recent
> > it
> > other
> > that,
> > > > > > Hi Guys and Gals:
> > call
> > > > > > Thanks
> > > > > > Safe travels,
> > > > > > Duncan, Oklahoma
