Rust Conversion and Rust Stop Paints
08-22-2010, 03:27
Anyone have long time experience with rust conversion and rust paint products
and seen them work for 5 plus years? I drive my 84 Pt 40 in the winter when there is salt on the roads and live on Chesapeake Bay where there is salt and moisture in the air. And I hope to continue using my BB for years to come. 1. Most rust areas that I am dealing with are associated with engine compartments, frame and areas where appearance is not critical. 2. Is there any product that will deal with oily surfaces that cannot be reached? 3. How long will these products slow down rust? 4. Product cost is not an issue. Labor and experience required for surface prep is an issue. 5. Who makes the best products that will deal with structural rust issues and provide a durable surface? Tks BC |
08-23-2010, 01:11
Take a look at this Durabak this stuff, is not just for your truck bed. You can get this with out the rubber granules. I will using this in my cargo holds next year. Something you need to know, once you put it on, you would have a hell of a time getting it off.......Hope this helps...
J R & Deane Living on the side of the road, in the middle of nowhere (New Mexico) Bug Smasher: 1982 PT40 KarKaddy SS/02 Windstar Cruiseairs & Roof Airs Red 6V92 Photobucket http://tinyurl.com/cn85dx --- In WanderlodgeForum@yahoogroups.com, "ken.hvac-conserve@..." > > Anyone have long time experience with rust conversion and rust paint products and seen them work for 5 plus years? > > I drive my 84 Pt 40 in the winter when there is salt on the roads and live on Chesapeake Bay where there is salt and moisture in the air. And I hope to continue using my BB for years to come. > > 1. Most rust areas that I am dealing with are associated with engine compartments, frame and areas where appearance is not critical. > 2. Is there any product that will deal with oily surfaces that cannot be reached? > 3. How long will these products slow down rust? > 4. Product cost is not an issue. Labor and experience required for surface prep is an issue. > 5. Who makes the best products that will deal with structural rust issues and provide a durable surface? > > Tks BC > |
08-23-2010, 04:43
I've had great success with POR15. David Brady '02 LXi, NC On 8/22/2010 11:27 AM, "ken.hvac-conserve@att.net" wrote:
09-07-2010, 00:02
POR 15. Use as directed. Rock solid when applied properly. Permanent. Cannot
expose to UV. If exposed it must be coated. --- In WanderlodgeForum@yahoogroups.com, "jr182pilot" > > Take a look at this Durabak <http://www.durabakcompany.com/index.htm> > this stuff, is not just for your truck bed. You can get this with out > the rubber granules. I will using this in my cargo holds next year. > Something you need to know, once you put it on, you would have a hell of > a time getting it off.......Hope this helps... > > > J R & Deane > Living on the side of the road, > in the middle of nowhere (New Mexico) > Bug Smasher: 1982 PT40 > KarKaddy SS/02 Windstar > Cruiseairs & Roof Airs > Red 6V92 > Photobucket http://tinyurl.com/cn85dx <http://tinyurl.com/cn85dx> > > > > > --- In WanderlodgeForum@yahoogroups.com, "ken.hvac-conserve@" > > > > > Anyone have long time experience with rust conversion and rust paint > products and seen them work for 5 plus years? > > > > I drive my 84 Pt 40 in the winter when there is salt on the roads and > live on Chesapeake Bay where there is salt and moisture in the air. And > I hope to continue using my BB for years to come. > > > > 1. Most rust areas that I am dealing with are associated with engine > compartments, frame and areas where appearance is not critical. > > 2. Is there any product that will deal with oily surfaces that cannot > be reached? > > 3. How long will these products slow down rust? > > 4. Product cost is not an issue. Labor and experience required for > surface prep is an issue. > > 5. Who makes the best products that will deal with structural rust > issues and provide a durable surface? > > > > Tks BC > > > |
09-07-2010, 03:53
Permament, but easily removed with Klean-Strip Aircraft Paint Remover, part no: QAR343 www.kleanstripauto.com David Brady '02 LXi, NC On 9/7/2010 8:02 AM, Leroy wrote:
09-07-2010, 10:02
I tried the Durabak UV with the nonslip in it on my entrance steps. I used the black on it. It looks good if it holds up. I never found anything that I liked on them before. It was easy to put on also. I used there roller to put it on. I also tried it with a under coating spray gun which was easier. Â Â David that is good to know that Klean-Strip will remove Por-15 if I ever have to take mine off.
Don Spithaler 89 SP 36' Butler, PA Â Â On Tue, Sep 7, 2010 at 11:53 AM, david brady <"dmb993@earthlink.net"> wrote:
09-30-2010, 17:48
09-30-2010, 18:36
I've use POR-15 for about 5 years. Great stuff. You can achieve a great high
gloss finish with POR-15 more easily than almost any paint I have tried. I have used it on heavily rusted frame members as well as prepainted surfaces. The only (optional) pre-painting chemical is another POR-15 product called Marine Clean. (A very caustic, aggressive water based solvent that removes oily film which POR-15 doesn't like.) Spray it on, hose it off. As I read the instructions the only time a primer is recommended is when you have new metal. I have primed some surfaces before I used POR-15. I didn't like it. The Rustolem primer I used was much softer, when dried, than the POR-15. I didn't like having a softer underlayer for the POR-15. It can be applied directly to heavily rusted (descaled) iron and seems to me to work very well, because of the extra tooth the rusted surface provides. POR-15 is one part, moisture curing, polyurethane paint. Incredibly tough. You can almost not abrade it with sand paper. You can just abrade it with a file and a strong arm. Striking the finish with a hammer doesn't do much unless you deform the metal underneath. At least 2 coats are recommended with about 3-4 hours between coats. In desert climates almost 8 to 24 hours can be required between coats (it's moisture cured.) Cleanup is a bit of a bear. Lacquer thinner works. If you buy POR-15 I would strongly suggest small containers. Ebay is where I bought my supplies although many automotive paint stores also carry it (usually in quart cans). I recently use POR 2500 degree high temperature paint on my new muffler system. I'll tell you how it works in 5 years. Happy trails, Eric Perplies 96 PT-42 In WA loading up to follow the sun. |
