12 volt fuse location
08-25-2010, 07:37
Does anyone know where the 12 volt fuse location is for the 12 volt air
compressor for the toilet? I have looked at the wiring diagrams and cannot find it. The compressor has a wire going to a 12 volt receptacle in the bay in that same area it is also not working. Robert rahn 1988 pt 40 Kalispell, mt |
08-25-2010, 10:20
Thinking back a few years, I recall finding the compressor 12v wire/fuse stuffed in the bay door jamb near the compressor. Might have been a receptacle there too. My notes from back then show...that I wanted to do an upgrade...no reason documented...and a fuse and on/off switch were installed under the kitchen sink for the 12v air compressor. Power came from the garbage disposal switch box in that area. Ran new wires (along with several other project wires) down thru the floor and thru the top of the bay to the compressor.ÃÂ
Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Wed, Aug 25, 2010 at 12:37 PM, chaunceyboyblu <"chaunceyboyblu@hotmail.com"> wrote:
08-26-2010, 22:30
Ours is a 2000 LXI but the fuse is located in the panel behind the co-pilots
footrest: #59. Hope this helps. RJJ in MN --- In WanderlodgeForum@yahoogroups.com, "chaunceyboyblu" wrote: > > Does anyone know where the 12 volt fuse location is for the 12 volt air compressor for the toilet? I have looked at the wiring diagrams and cannot find it. The compressor has a wire going to a 12 volt receptacle in the bay in that same area it is also not working. > > Robert rahn > 1988 pt 40 > Kalispell, mt > |
