onan wiring harness help
06-22-2005, 23:12
have you tried turning off all the circuit breakers in the coach?
when you hook up the harness, is the source selector in the coach on generator? or do you have the automatic switch over box? make sure you have no load attached to the generator when you connect the harness,,, that will be the first step in troubleshooting the thing. if the problem still persists with your being absolutely sure there is no load on the system, it will tell you it is in the wiring. if the problem goes away, first switch on the gen select to gen (if you have the manual selector) then,start turning on circuit breakers until you see which one loads down the generator. good hunting,,, day jax fl 83 pt-40 In a message dated 6/23/2005 10:25:17 AM Eastern Standard Time, mw88fc@... writes: > Subj: [WanderlodgeForum] onan wiring harness help > Date:6/23/2005 10:25:17 AM Eastern Standard Time > From:mw88fc@... > Reply-to:WanderlodgeForum@yahoogroups.com > To:WanderlodgeForum@yahoogroups.com > Received from Internet: > > > > Good morning, > > I have an 88 fc with an 8 kw onan.\ That has problems associated with the > wiring harness > that goes from the onan control board to the gauges inside the coach.. > > > When the wiring harness is connected at the genny, the fault breaker trips > after 30 sec. > The real curious thing is that the genny keeps running with the breaker > tripped. ( I am > going to test the breaker today, as I think this is a seperate issue?) > Anyway, another > symptom is the when the wiring harness is connected, the genny runs like it > has a big load > on.... the engine souds more loaded than it does with both airs running. I > have tested all > the fault sensor that are located on the generator. and they are working > fine. > > > So, My questions are,,, > > Does the genny have fault sensors other than the ones on the generator > itself? > If so where are the located, and How do I troubleshoot them? > Are there any other things I can try or look for? > > > thanks > > mark walk > 88fc > 310 560 4454 > > > > > > > > > Yahoo! Groups Links > > To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > [Non-text portions of this message have been removed] |
06-23-2005, 02:24
Good morning,
I have an 88 fc with an 8 kw onan.\ That has problems associated with the wiring harness that goes from the onan control board to the gauges inside the coach.. When the wiring harness is connected at the genny, the fault breaker trips after 30 sec. The real curious thing is that the genny keeps running with the breaker tripped. ( I am going to test the breaker today, as I think this is a seperate issue?) Anyway, another symptom is the when the wiring harness is connected, the genny runs like it has a big load on.... the engine souds more loaded than it does with both airs running. I have tested all the fault sensor that are located on the generator. and they are working fine. So, My questions are,,, Does the genny have fault sensors other than the ones on the generator itself? If so where are the located, and How do I troubleshoot them? Are there any other things I can try or look for? thanks mark walk 88fc 310 560 4454 |
06-23-2005, 04:17
Mark,
I suggest that you go to the newsgroup, rec.outdoors.rv-travel and ping Alan Robinson. Alan is in the generator business and knows Onan generators inside and out. He is very helpful. It seems like the more knowledgeable people that were here have left or are not answering tech questions any more... George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD mw88fc wrote: > Good morning, > > I have an 88 fc with an 8 kw onan.\ That has problems associated with the wiring harness > that goes from the onan control board to the gauges inside the coach.. > > > When the wiring harness is connected at the genny, the fault breaker trips after 30 sec. > The real curious thing is that the genny keeps running with the breaker tripped. ( I am > going to test the breaker today, as I think this is a seperate issue?) Anyway, another > symptom is the when the wiring harness is connected, the genny runs like it has a big load > on.... the engine souds more loaded than it does with both airs running. I have tested all > the fault sensor that are located on the generator. and they are working fine. > > > So, My questions are,,, > > Does the genny have fault sensors other than the ones on the generator itself? > If so where are the located, and How do I troubleshoot them? > Are there any other things I can try or look for? > > > thanks > > mark walk > 88fc > 310 560 4454 > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > |
06-23-2005, 04:34
Thanks,I sent him an email
mark --- In WanderlodgeForum@yahoogroups.com, George Lowry > Mark, > > I suggest that you go to the newsgroup, rec.outdoors.rv-travel and > ping Alan Robinson. Alan is in the generator business and knows Onan > generators inside and out. He is very helpful. It seems like the more > knowledgeable people that were here have left or are not answering > tech questions any more... > > George Lowry > '95 WBDA 4203 & GM 4106 (for sale) > Spearfish, SD > > mw88fc wrote: > > > Good morning, > > > > I have an 88 fc with an 8 kw onan.\ That has problems associated with the wiring harness > > that goes from the onan control board to the gauges inside the coach.. > > > > > > When the wiring harness is connected at the genny, the fault breaker trips after 30 sec. > > The real curious thing is that the genny keeps running with the breaker tripped. ( I am > > going to test the breaker today, as I think this is a seperate issue?) Anyway, another > > symptom is the when the wiring harness is connected, the genny runs like it has a big load > > on.... the engine souds more loaded than it does with both airs running. I have tested all > > the fault sensor that are located on the generator. and they are working fine. > > > > > > So, My questions are,,, > > > > Does the genny have fault sensors other than the ones on the generator itself? > > If so where are the located, and How do I troubleshoot them? > > Are there any other things I can try or look for? > > > > > > thanks > > > > mark walk > > 88fc > > 310 560 4454 > > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > |
06-23-2005, 04:34
