jacking up the bus
09-07-2010, 12:59
jacking up the bus
Where are the safe points that you can jack up the motor home with out using the
levlors.
Joe
1984 PT40
09-07-2010, 13:03
jacking up the bus
Joe, what project do you have in mind?
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Tue, 9/7/10, mjzakowski <mjzakowski@...> wrote:
Subject: [WanderlodgeForum] jacking up the bus
Date: Tuesday, September 7, 2010, 7:59 PM
Where are the safe points that you can jack up the motor home with out using the levlors.
Joe
1984 PT40
09-08-2010, 05:01
jacking up the bus
Bob when you cracked a windshield was it a Wanderlodge?
On 8 September 2010 09:49, Robert Johannesen <"packratfxr@yahoo.com"> wrote:
Joe - also when you jack it up, be sure to do each side together or very gradually. If you jack one corner too much you can crack a windshield....don't ask how I learned this.
I made some heavy duty ramps and get the rig about 12 inches off the ground before I start jacking and placing HD jack stands and blocks.
Bob Johannesen, 91 WLWB "Seldom Blue" - off to  the Grand Canyon in the AM
Argyle, TX
Sent: Wed, September 8, 2010 11:03:29 AM
Subject: Re: [WanderlodgeForum] jacking  up the bus
Just a word of caution, if you lift the rear wheels off the ground the
Coach will roll if the front tires are not fully blocked to prevent the roll.
Safe travels,
"84FC35 "Ruff Diamond"
Duncan, Oklahoma
At 09:50 AM 9/8/2010 -0500, you wrote:
>Does any one know where the jacking points on the rear of the bus? Might
>have to remove the tranny and the levelers do not jack up high enough.
>Joe
>1984 pt 40
>__________________________________________________________
Rob, Sue and Joey Robinson
09-08-2010, 06:16
jacking up the bus
Yes - 91 WLWB - I did jack it up uniformly - I let it down unevenly!
Sent: Wed, September 8, 2010 12:01:32 PM
Argyle, TX
Safe travels,
Duncan, Oklahoma
>Joe
>1984 pt 40
09-08-2010, 06:48
jacking up the bus
Thank you Bob. Good to know. I have have been aggressive in my jacking and de-jacking in the past. Will keep your advice in mind in the future.
Argyle, TX
Safe travels,
Duncan, Oklahoma
>Joe
>1984 pt 40
