8V92 Thermal Cycling, Weir Thermostat
09-11-2010, 11:28
Folks,
Have any of you two-stroke diesel owners tried a Weir
Thermostat?
I learned that the reason the S60 behaves the way it does;
that is, able to operate at any temp within it's t-stat operating
range in temperature equilibrium w/o the fan on high speed is
because of the Weir t-stat.
Basically the Weir t-stat starts to open a small amount and will
remain open a little if the cooling system temperature stays the
same. If the coolant gets a little hotter, then the Weir t-stat
opens
a little more in a very controlled manner. This makes for much
better coolant temperature control and fluid flow control. The
Weir t-stat came on the scene around 1997 and is in common
automotive and trucking use today.
The Weir provides just a fraction of the flow of a traditional
t-stat
at the same operating temperature. Traditional t-stats can cause
thermal cycling as the t-stats were basically open and close
devices.
This behavior lets a flood of cold coolant into the engine which
then
closes the t-stat. The engine then heats up, the fan kicks on, the
t-stat opens, and again a flood of cold coolant enters the engine
which closes the t-stat, and the cycle repeats.
Apparently the Weir t-stats are available for the early two-stroke
diesels and can be retrofitted.
__________________
David Brady
'02 LXi, NC
