Suspension & Air Horn - New Experience
09-13-2010, 16:18
New Experienceââ¬Â¦Night before last the partying ladies were sitting in
our coach driver seat with my hat on having their pictures taken like they were driving the coach. They were having a great time. Fast forward to this amââ¬Â¦I tried to air up the coach. It would not air up. The optional on board electric air compressor just kept running. I started the big engine and after a few seconds heard a fairly loud sound coming from the front top of the coach. I shut the big engine down and the sound went away in a few seconds. The optional air compressor continued to run. I crawled up on the roof and found the speakers emitting low noise. Climbed down, went into the coach and did the ââ¬Åwhat the **** was messed withââ¬Â review. I discovered the steering wheel horn button was stuck in the down position. Tapped on the horn button and it raised up to the normal positionââ¬Â¦and the coach aired up. Apparently the compressor air was heading for the horns and bleeding off. Has anyone experienced this one? Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA |
09-13-2010, 16:46
Some thing similar only the dimmer style switch on the floor board was the
culprit. I put a mod on my to do list of adding 2 led's in the overhead to one of the blanks. The led's would need a resistor in line but one hot going to the valve on one side and the other to the curb side valve located in the overhead. This would give a visual check sum for the problem. Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: Curt Sprenger Sender: WanderlodgeForum@yahoogroups.com Date: Mon, 13 Sep 2010 21:18:19 To: WanderlodgeForum Reply-To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Suspension & Air Horn - New Experience New Experienceââ¬Â¦Night before last the partying ladies were sitting in our coach driver seat with my hat on having their pictures taken like they were driving the coach. They were having a great time. Fast forward to this amââ¬Â¦I tried to air up the coach. It would not air up. The optional on board electric air compressor just kept running. I started the big engine and after a few seconds heard a fairly loud sound coming from the front top of the coach. I shut the big engine down and the sound went away in a few seconds. The optional air compressor continued to run. I crawled up on the roof and found the speakers emitting low noise. Climbed down, went into the coach and did the ââ¬Åwhat the **** was messed withââ¬Â review. I discovered the steering wheel horn button was stuck in the down position. Tapped on the horn button and it raised up to the normal positionââ¬Â¦and the coach aired up. Apparently the compressor air was heading for the horns and bleeding off. Has anyone experienced this one? Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA ------------------------------------ Yahoo! Groups Links |
