can't get water system to pressurize
06-23-2005, 04:26
Make sure your water fill switch is off, and your drain switch is off. The
switches that control the water heater drain, etc, should be checked to make sure one of the switches weren't inadvertently put in the wrong position. If this fails, it could be the sporlan valve. BB has rebuild kits for around 20 bucks, or maybe you could just take your's apart, make sure it's clean and free from any debris (calcium deposits and even a small grain of sand can cause the sporlan valve not to close/open properly). Also, check the little screen where you attach the shoreline hose...it gets clogged easily. If you get normal pressure at some outlets, and not at others, check the screen on the faucet spout...this commonly gets clogged with sediment and small particles of sand, etc, which restricts the water flow. Rarely is it the shoreline valve (the place where you attach the garden hose). Good luck. Kevin McKeown Yorba Linda, CA 1986 38' PT [Non-text portions of this message have been removed] |
06-23-2005, 07:28
Hi, folks--
This is kind of an emergency for us, as we are preparing leave tomorrow for the PNW Bird retreat in Pacific Beach, WA. Stew all of a sudden can't get the water system to pressurize--either with 12-volt pump or faucet water. He asks, could it be the diverter valve that fills the tank, and if so, what can be done, short of buying a new one? Or, anyone have any other suggestions to try checking, please? Many, many thanks in advance for any help you can offer! Jo-Ski (and Stew) "The Bird Abides" '83-FC 35 RB Blaine, WA [Non-text portions of this message have been removed] |
06-23-2005, 07:57
Breaking news--progress. Stew found a screw was loose on the diverter valve; now
we have water pressure from the faucet. Still don't know if we're getting pressure from 12-volt pump. Jo-Ski ----- Original Message ----- From: Jo-Ski To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 23, 2005 12:28 PM Subject: [WanderlodgeForum] can't get water system to pressurize Hi, folks-- This is kind of an emergency for us, as we are preparing leave tomorrow for the PNW Bird retreat in Pacific Beach, WA. Stew all of a sudden can't get the water system to pressurize--either with 12-volt pump or faucet water. He asks, could it be the diverter valve that fills the tank, and if so, what can be done, short of buying a new one? Or, anyone have any other suggestions to try checking, please? Many, many thanks in advance for any help you can offer! Jo-Ski (and Stew) "The Bird Abides" '83-FC 35 RB Blaine, WA [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-24-2005, 02:45
Hi, everyone--
Thanks to Kevin McKeown and Mike Bulriss for the GREAT information you both sent! Before we were actually able to get back to the computer to see your responses, Stew had fixed the problem (he was so proud of himself, so that's why I had to send this!)--it was indeed that loose screw on the diverter valve that Stew thinks had been ever-so-gradually loosening. Now the water pressure's better than ever! However, Kevin and Mike, please know that your info is a valuable contribution to the archives, and we will definitely be using it to see if we can further optimize the water system! Thanks so much again! Jo-Ski (also for Stew) "The Bird Abides" '83-FC 35 RB Blaine, WA [Non-text portions of this message have been removed] |
