Radiator header tank rust - filler neck replacement
10-06-2010, 13:27
I don't remember who posted the problem with the radiator header tank rusting, but I followed his advice and inspected mine - cut all the urethane foam away along with several layers of rusty pipe and sure enough, I could poke a hole in the tube with my thumb nail. I removed the tank (not an easy task- bolts are rusty also) which is stainless on my '91, with a mild steel pipe welded between the filler neck and the stainless tank. I finally found a source for the stainless steel filler neck andwill replace all with stainless steel. I am going to TIG weld a stainless coupling on the tank, then screw a stainless pipe with the filler neck into the coupling. It will probably never rust again, but it can be inspected and replaced w/o taking the tank out.
If any one needs one replaced let me know - I bought 4.
Bob Johannesen, Argyle, TX. '91 WLWB, "Seldom Blue"
10-10-2010, 02:25
10-10-2010, 02:34
Thanks Gary,
I am referring to the stainless resevoir tank hanging from the top of the engine compartment where the filler neck is located.Will have the necks here by Tuesday and I'm cutting the angle on the couplings today. We'll see how it works.
Bob J.
91 WLWB "Seldom Blue"
Argyle, TX
From: GARY MINKER To: WanderlodgeForum@yahoogroups.com Sent: Sun, October 10, 2010 9:25:02 AM Subject: Re: [WanderlodgeForum] Radiator header tank rust - filler neck replacement
