ARO Step control valve
11-15-2010, 17:21
a small amount of modification is needed
notably plugging extra ports cost 115.00 plus shipping it can be rebuilt --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > Stephen, > > Do you have more information? > > - Cost? > > - Direct replacement or modification required? > > - Can it be rebuilt? > > > > > > - Chuck Wheeler- > > 1982 FC 31SB Fort Worth TX > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of cape0001 > Sent: Sunday, November 14, 2010 7:06 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: ARO Step control valve > > > > > > We have step control valves > Stephen 97 bmc 37 > dupree Procucts > > --- In WanderlodgeForum@yahoogroups.com > > wrote: > > > > We developed a bad leak in the ARO step control valve during our trip last > > weekend. The spool valve was easy to rebuild using "O" rings from the > > faucet section of ACE hardware (3/4" X 1/8" thick - $0.29 each). The > problem > > is that the rubber on the back port of one of the pilot air valves is bad > so > > there is a leak when it is energized. There used to be kits available for > > these valves but I can't find any since IR bought ARO. > > > > - Has anyone found any parts to rebuild one of these valves lately? > > > > - Or does any one have an old valve around that I could buy for parts? > > > > - Or, lastly, does anyone have a part number for a valve that would > replace > > the current one? (ARO Part#5840-2929-02) > > > > > > > > We head north for the holidays and in very cold weather even a small leak > > creates problems. > > > > > > > > - Chuck Wheeler- > > > > 1982 FC 31SB Fort Worth TX > > > |
11-15-2010, 17:28
Give me a call and let’s arrange - Chuck 1982 FC 31SB From: a small amount of modification is needed notably plugging extra ports cost 115.00 plus shipping it can be rebuilt --- In "WanderlodgeForum%40yahoogroups.com", "Chuck Wheeler" > > Stephen, > > Do you have more information? > > - Cost? > > - Direct replacement or modification required? > > - Can it be rebuilt? > > > > > > - Chuck Wheeler- > > 1982 FC 31SB > > _____ > > From: "WanderlodgeForum%40yahoogroups.com" > [mailto:"WanderlodgeForum%40yahoogroups.com"] On Behalf Of cape0001 > Sent: Sunday, November 14, 2010 7:06 PM > To: "WanderlodgeForum%40yahoogroups.com" > Subject: [WanderlodgeForum] Re: ARO Step control valve > > > > > > We have step control valves > Stephen 97 bmc 37 > dupree Procucts > > --- In "WanderlodgeForum%40yahoogroups.com" > Wheeler" > wrote: > > > > We developed a bad leak in the ARO step control valve during our trip last > > weekend. The spool valve was easy to rebuild using "O" rings from the > > faucet section of ACE hardware (3/4" X 1/8" thick - $0.29 each). The > problem > > is that the rubber on the back port of one of the pilot air valves is bad > so > > there is a leak when it is energized. There used to be kits available for > > these valves but I can't find any since IR bought ARO. > > > > - Has anyone found any parts to rebuild one of these valves lately? > > > > - Or does any one have an old valve around that I could buy for parts? > > > > - Or, lastly, does anyone have a part number for a valve that would > replace > > the current one? (ARO Part#5840-2929-02) > > > > > > > > We head north for the holidays and in very cold weather even a small leak > > creates problems. > > > > > > > > - Chuck Wheeler- > > > > 1982 FC 31SB > > > |
