Front Suburban Furnace ????
12-18-2010, 04:46
The furnace is not lighting. But my problem is how to get to it? It is located
under a cabinet and you cannot even see it. I don't want to damage anything if I can avoid it? Thanks for your response. The Bird PT 40 1989 C E Wooten Madisonville, Tx |
12-18-2010, 08:07
12-19-2010, 06:56
Unfortunately, Bluebird appears to have installed the front furnace and built
the cabinet around it on the 89 WB. Mine failed last winter and the only way to get at it is to remove the sofa. I didn't have the time or the energy so I had mine repaired at Texas Custom Coach. David Hanvy 89WB Bandera TX (presently) --- In WanderlodgeForum@yahoogroups.com, "fmc360" > > The furnace is not lighting. But my problem is how to get to it? It is located under a cabinet and you cannot even see it. > > I don't want to damage anything if I can avoid it? > > Thanks for your response. > > > > The Bird PT 40 1989 > C E Wooten > Madisonville, Tx > |
12-19-2010, 07:52
12-20-2010, 02:34
> > The furnace is not lighting. But my problem is how to get to it? It is located under a cabinet and you cannot even see it. > > I don't want to damage anything if I can avoid it? > > Thanks for your response. > > > > The Bird PT 40 1989 > C E Wooten > Madisonville, Tx On my '90 PT40, the front panel of that cabinet was held in place with magnetic catches. A couple of screws, accessed from under the sofa and inside the sink cabinet allowed the furnace to slide right out. (A duct had to be disconnected too.) > |
