AIR SYSTEM ??
01-19-2011, 23:34
AIR SYSTEM ??
Your air should be at 120 psi in under 10 minutes at idle from empty.
If you leak faster than that, have the entire machine gone through with an ultrasonic leak detector,,, NOT BUBBLES.
gary
85pt40
--- On Mon, 1/10/11, Don Bradner wrote:
Subject: Re: [WanderlodgeForum] Re: AIR SYSTEM ??
Date: Monday, January 10, 2011, 12:01 PM
I really don't know how long it takes to air my coach up with the engine because I never do it that way. My startup procedure involves using both block heater and aux air pump from the time I get up on any morning I'm going to travel - that way I can just start and almost immediately roll.
Don Bradner
90 PT40 "Blue Thunder"
On 1/10/2011 at 2:44 PM jamiejbrandt wrote:
>THANKS IT WAS VERY HELPFUL IM GOING TO GET THE PARTS TODAY
>DON HOW LONG DOSE IT TAKE FOR YOUR RV TO REACH FULL PRESSURE
>I HEAR AIR FROM UNDER THE FRONT RIGHT BEHIND THE GENNY ABOUT IN THE CENTER
>AND I LOOKED AND I DO SEE SOME KIND OF VALVES BUT IM LEARY OF GETTING TO
>FAR UNDER THE RV AND SCREWING WITH THEM I NEED TO FIND A COMPANY THAT
>DOSE THIS I GUESS ANYWAY THANKS AGAIN
>JAMIE BRANDT
>1990 WB40
>FLORIDA
>--- In WanderlodgeForum@yahoogroups.com, "Don Bradner"
>wrote:
>> The switch/valves are Clippard MJTV-4, still available from the
>manufacturer:
>> http://www.clippard.com/store/display_de...sku=MJTV-4
>> I've replaced both of mine as they leaked in increasing fashion.
>> Those small leaks, though, won't cause the problem you are seeing. You
>have a significant leak somewhere, probably in the air bag system, or in
>the brakes.
>> You have two air gaugues. One is for the tag-axle air bags, and the
>other is for the brakes front and rear (two needles). If you shut down,
>both of those should hold air for a significant amount of time. If they
>do, then the problem is elsewhere.
>> When I first got mine, the front air bags would significantly drop in
>less than 15 minutes. I'm not the one who fixed it, but I'm told that the
>leveler valve was actually coming apart. Point, though, is that one way or
>another shutting down when you have full air should show a symptom
>somewhere.
>> Don Bradner
>> On 1/8/2011 at 8:40 PM jamiejbrandt wrote:
>> >I HAVE A 1990 WB40 AND WHEN I START IT IT TAKES ALONG TIME TO BUILD UP
>> >AIR ATLEAST I THINK ITS ALONG TIME ITS NEW TO ME AND IM NOT SURE HOW
>LONG
>> >IT SHOULD TAKE
>> >ALSO I HAVE TO PUT IT IN HIGH RPM TO GET IT TO GO UP
>> >AFTER I GET IT UP TO ABOUT 115 WHEN I BACK OUT OF DRIVEWAY BY THE TIME I
>> >GET IT TO THE ROAD IT DROPS TO 80 THE ONLY TIME IT STAYS HIGH IS ON THE
>> >ROAD AT A GOOD SPEED IS THIS NORMAL
>> >ALSO THE HOSES AND THE SWITCH PLATE FOR THE GREY AND BLACK WATER DUMP IS
>> >LEAKING A BIT NOT THAT BAD DOES ANYONE KNOW WHERE TO GET REPLACMENT
>PARTS
>> >ALL HELP IS APPRCIATED THANKS
>> >JAMIE BRANDT
>> >1990 WB40
>> >FLORIDA
>Yahoo! Groups Links
