Wheel Polishing Service
01-30-2011, 14:22
Hi all: Anyone know if there is a wheel polishing service in the Dallas, Ft.
Worth area or around Houston? If you know of any, please drop me an email.
Thanks,
02-02-2011, 08:28
Ron, not sure that ypu wanted t do this by your self or get some one to do it for you but ..........
call Holland Motor Coach and talk to the parts depat. and tell them you want the wheel cleaner that they use Holland was a lng time BB Dealer) I can nt remember the brand name but It works well. I use this and witha "Mothers" polishing Ball. I use two size ball polishers. one large ne for the rim portion and one small one for the lug nut area. I have the timing down to 15 minutes per wheel.
If your wheels are a mess I would suggest that you get a pro do to it and then follow up with your own work pro's get about $35.00 per wheel in Michigan it might be worth $200.00 for the first time.
Scooter 2000 40XL
Ocqueoc, MI
Date: Mon, 31 Jan 2011 02:22:20 +0000
Subject: [WanderlodgeForum] Wheel Polishing Service
Hi all: Anyone know if there is a wheel polishing service in the Dallas, Ft. Worth area or around Houston? If you know of any, please drop me an email.
Thanks,
02-02-2011, 14:46
Ron..When I got new tires for the coach, the tire Dealer had them done for about
$35 a wheel, and the wheels really needed it bad. The wheels did not have
tires mounted at the time, but when the wheels came back, they looked new.. So
check and see if any Truck Tire dealer in your area can help..
Jack Smith
1973FC31 (For Sale)
Warm,Clear SoCal..
wheel.
> Scooter 2000 40XL
> Ocqueoc, MI
> From: remarabito@...
> Thanks,
02-02-2011, 15:08
Most bigger truck stops have someone hanging around. Last time I had mine done was from a guy that approached me at a Flying J while I was fueling. I brushed him off, but he was hitting all the truckers up, so after I paid, I verified his price and his crew did a great job. I think McMahan said there was a similar guy at the Flying J in Waco.
FWIW,
1991 WB40 "Texas Minivan"
San Antonio, TX - 21 degrees two hours ago when I last checked
--- On Wed, 2/2/11, jackcj7 wrote:
Subject: [WanderlodgeForum] Re: Wheel Polishing Service
Date: Wednesday, February 2, 2011, 8:46
PM
Ron..When I got new tires for the coach, the tire Dealer had them done for about $35 a wheel, and the wheels really needed it bad. The wheels did not have tires mounted at the time, but when the wheels came back, they looked new.. So check and see if any Truck Tire dealer in your area can help..
Jack Smith
1973FC31 (For Sale)
Warm,Clear SoCal..
> Scooter 2000 40XL
> Ocqueoc, MI
> Thanks,
02-02-2011, 15:26
My wheels also need polishing but the aluminum has started to flak off. suggestions
Bjowers
1983 PT 35
PC FL
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of jackcj7
Sent: Wednesday, February 02, 2011 8:46 PM
Jack Smith
1973FC31 (For Sale)
Warm,Clear SoCal..
> Scooter 2000 40XL
> Ocqueoc, MI
> Thanks,
02-03-2011, 03:37
It is getting too hard on my back to do the wheels anymore. I'm looking for a
service to do them.
Stuck in the deep freeze.
wheel.
> Scooter 2000 40XL
> Ocqueoc, MI
> Thanks,
02-03-2011, 03:39
Thanks for the suggestion. I'll look into it.
> Jack Smith
> 1973FC31 (For Sale)
> Warm,Clear SoCal..
wheel.
> > Scooter 2000 40XL
> > Ocqueoc, MI
> > From: remarabito@
> > Thanks,
02-03-2011, 03:43
O.K. Mike. I'm not going through Waco. I'll check with the Dallas Flying J or
maybe find someone while in the Houston area and the Lonestar Birds Rally.
R.R. (Ron) Marabito, Dallas, tX 92WB40
--- In WanderlodgeForum@yahoogroups.com, Michael Bulriss <mbulriss@...> wrote:
> FWIW,
> Mike Bulriss
> San Antonio, TXÂ - 21 degrees two hours ago when I last checked
> From: jackcj7
> Date: Wednesday, February 2, 2011, 8:46 PM
> Â
> Jack Smith
> 1973FC31 (For Sale)
> Warm,Clear SoCal..
wheel.
> > Scooter 2000 40XL
> > Ocqueoc, MI
> > From: remarabito@
> > Thanks,
02-03-2011, 03:46
Surely you do not have aluminum flaking off. If that is true, you need to get
new wheels. You might have wheels that had a protective lacquer coating and
that is what is flaking. If that is the case, the coating would have to be
completely removed to allow polishing.
> suggestions
> Bjowers
> 1983 PT 35
> PC FL
> Jack Smith
> 1973FC31 (For Sale)
> Warm,Clear SoCal..
> , Al Scudder
> minutes per wheel.
> > Scooter 2000 40XL
> > Ocqueoc, MI
> > From: remarabito@
> email.
> > Thanks,
