Engine won't start or Primus
02-28-2011, 05:26
Hello,
I have a 1994 WB with an 8v92. I have been away for 4 months and just got back
this past weekend. I wanted to start the engine so I tried starting the Primus
in order to pre-warm the engine due to the cold temperature we've had for a few
months. The Primus would not start. I checked the Propane switch, and it was on,
the stove was working and so was the refrigerator. I tried to turn it on a few
times incase there was and air in the line, but it never started. It there
another safety switch for the Primus? I started the engine and the primus
before I left and all worked properly.
When I try to start the engine it turns very slowly and does not turn fast
enough to start.
The only thing that I noticed was the "Neutral" light on the transmission panel
is on.
Does the 1994 Bird have an electric heated for the engine? I saw a switch that
is on the right side of the consul that says cold start.
Any help would be appreciated.
Thanks
Nelson Slinkman
1994 WB
Westminster, Md
02-28-2011, 06:06
Nelson,
What readings do you show on the two volt meters on the dash (engine and coach)?
Sounds to me like your batteries are down.
1991 WB40 "Texas Minivan"
--- In WanderlodgeForum@yahoogroups.com, "nelsons" wrote:
> Hello,
enough to start.
panel is on.
> Thanks
> Nelson Slinkman
> 1994 WB
> Westminster, Md
02-28-2011, 06:06
If it is set up the same as my 1993 pull
down the drawer front under the kitchen sink, there should be a switch there
for the electric engine heater. For this to work you need to be plugged
in or on your generator. When you were parked did you tie the engine
batteries to the house so they would be charged? If not there is a switch
on the dash AUX Battery, if it is off turn to on to on to charge the engine
batteries.
The cold start switch goes to an ether
cylinder in the engine bay that is most likely empty.
Steve Quandt 1993 PT40
Iron Mountain, MI
Now in WARM Marble Falls TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of nelsons
Sent: Monday, February 28, 2011
11:26 AM
Subject: [WanderlodgeForum] Engine
Hello,
on, the stove was working and so was the refrigerator. I tried to turn it on a
few times incase there was and air in the line, but it never started. It there
enough to start.
transmission panel is on.
Thanks
Nelson Slinkman
1994 WB
Westminster, Md
02-28-2011, 06:31
Hello Mike,
Just checked both meters. They are both on 14 volts. I tried to start it again
and it was still was slow and would not spin fast enought to crank up.
Thanks
Nelson Slinkman
1994 WB40
Westminster, Md
--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote:
> Nelson,
coach)? Sounds to me like your batteries are down.
> Mike Bulriss
> San Antonio, TX
> > Hello,
back this past weekend. I wanted to start the engine so I tried starting the
Primus in order to pre-warm the engine due to the cold temperature we've had for
a few months. The Primus would not start. I checked the Propane switch, and it
was on, the stove was working and so was the refrigerator. I tried to turn it on
a few times incase there was and air in the line, but it never started. It there
enough to start.
panel is on.
that is on the right side of the consul that says cold start.
> > Thanks
> > Nelson Slinkman
> > 1994 WB
> > Westminster, Md
02-28-2011, 06:51
Hello Mike,
I could not find any switch for electric heater behind the pull down
drawer. There was only an "start Gen" "LP on/off" and water pump switch. Yes,
the switch was "on" to charge both sets of batteries. I am sure the ether tank
is empty I have had this bus for 10 years and never used it. The bus only has
31000 miles on it.
Thanks for your help.
Nelson SLinkman
1994 WB 40'
Westminster, Md
--- In WanderlodgeForum@yahoogroups.com, "Steve Quandt" wrote:
> If it is set up the same as my 1993 pull down the drawer front under the
> kitchen sink, there should be a switch there for the electric engine heater.
> For this to work you need to be plugged in or on your generator. When you
> were parked did you tie the engine batteries to the house so they would be
> charged? If not there is a switch on the dash AUX Battery, if it is off
> turn to on to on to charge the engine batteries.
> The cold start switch goes to an ether cylinder in the engine bay that is
> most likely empty.
> Iron Mountain, MI
> _____
> Sent: Monday, February 28, 2011 11:26 AM
> Subject: [WanderlodgeForum] Engine won't start or Primus
> Hello,
> for a few months. The Primus would not start. I checked the Propane switch,
> and it was on, the stove was working and so was the refrigerator. I tried to
> turn it on a few times incase there was and air in the line, but it never
> started. It there another safety switch for the Primus? I started the engine
> and the primus before I left and all worked properly.
> enough to start.
> panel is on.
> Thanks
> Nelson Slinkman
> 1994 WB
> Westminster, Md
02-28-2011, 07:08
IMO your engine batteries are just too weak. If charging them does get some cranking power, trying jumping them (if you are a member of Good Sam or other service, it may be worth the call). Even then, if you have one really bad battery, jumping may not help and replacing them may be your next alternative. The gages on the dash really only give you an indication of voltage at the moment and although lookin' good, may not be a good indication of cranking power.
Tying you house and engine batteries together with the switch on the dash could get you some cranking power, and heating up the batteries may help (my switch for the battery heat is under the sink in my 91WL). But even those assists may not overcome a bad or weak bank of batteries.
Roger Webb - Cedar Rapids, IA
91WL (sitting in NC)
-----Original Message-----
Sent: Mon, Feb 28, 2011 7:51 am
Subject: [WanderlodgeForum] Re: Engine won't start or Primus
Hello Mike,
drawer. There was only an "start Gen" "LP on/off" and water pump switch. Yes, the switch was "on" to charge both sets of batteries. I am sure the ether tank is empty I have had this bus for 10 years and never used it. The bus only has 31000 miles on it.
Nelson SLinkman
1994 WB 40'
Westminster, Md
> most likely empty.
> Iron Mountain, MI
> _____
> From: "WanderlodgeForum%40yahoogroups.com"
> [mailto:"WanderlodgeForum%40yahoogroups.com"] On Behalf Of nelsons
> Hello,
> enough to start.
> panel is on.
> Thanks
> Nelson Slinkman
> 1994 WB
> Westminster, Md
02-28-2011, 07:14
That should say if charging them does not get some cranking power
RWW
Sent: Mon, Feb 28, 2011 8:09 am
Subject: Re: [WanderlodgeForum] Re: Engine won't start or Primus
To: WanderlodgeForum <"WanderlodgeForum@yahoogroups.com">
Hello Mike,
Nelson SLinkman
1994 WB 40'
Westminster, Md
> most likely empty.
> Iron Mountain, MI
> _____
> Hello,
> enough to start.
> panel is on.
> Thanks
> Nelson Slinkman
> 1994 WB
> Westminster, Md
02-28-2011, 07:30
Thank you Roger,
I think you are correct about the condition of the batteries. Could you
recommend which ones to purchase for replacement? Could not find the Battery
Heat Switch. Sure do miss Dean from Wanderlodge when you have a problem, what
would all we do without this forum.
Thanks
Nelson Slinkman
1994 WB 40'
Westminster, Md
power.
> From: nelsons
> Hello Mike,
31000 miles on it.
> Nelson SLinkman
> 1994 WB 40'
> Westminster, Md
> > most likely empty.
> > Iron Mountain, MI
> > _____
> > Hello,
> > enough to start.
> > panel is on.
> > Thanks
> > Nelson Slinkman
> > 1994 WB
> > Westminster, Md
02-28-2011, 07:43
Oh no!. You have asked one of the most dreaded questions on the forum ... what battery is the best?? ... good luck, there are lots of opinions. I've got Interstate, but that is just because it was easy to do. Wait for 24 hours and I'm sure you'll have at least 6 different recommendations.
Now I'm not making fun of anyone ... I just know batteries and tires generate lots of responses. Have fun folks.
91 WL - sitting in NC
Sent: Mon, Feb 28, 2011 8:30 am
Thank you Roger,
I think you are correct about the condition of the batteries. Could you recommend which ones to purchase for replacement? Could not find the Battery Heat Switch. Sure do miss Dean from Wanderlodge when you have a problem, what would all we do without this forum.
Thanks
Nelson Slinkman
1994 WB 40'
Westminster, Md
> From: nelsons
> To: WanderlodgeForum <"WanderlodgeForum%40yahoogroups.com">
> Hello Mike,
> Nelson SLinkman
> 1994 WB 40'
> Westminster, Md
> > most likely empty.
> > Iron Mountain, MI
> > _____
> > Hello,
> > enough to start.
> > panel is on.
> > Thanks
> > Nelson Slinkman
> > 1994 WB
> > Westminster, Md
02-28-2011, 08:45
Thanks Roger,
Let see what happens.
Have a great day.
Nelson
> From: nelsons
> Thank you Roger,
> Thanks
> Nelson Slinkman
> 1994 WB 40'
> Westminster, Md
power.
> > From: nelsons
> > Hello Mike,
> > Nelson SLinkman
> > 1994 WB 40'
> > Westminster, Md
heater.
> > > most likely empty.
> > > Iron Mountain, MI
> > > _____
> > > Hello,
had
switch,
to
engine
> > > enough to start.
> > > panel is on.
> > > Thanks
> > > Nelson Slinkman
> > > 1994 WB
> > > Westminster, Md
