BOTW - Added Information
03-27-2011, 06:51
Part of the fun for me about the Bird of the Week feature is just not seeing all the Birds, but also seeing neat places to go or stop off at. On last week's picture, I was interested in learning more and Bob was kind enough to post added info on the site and the picture.
Likewise on this week's picture, I was interested in learning more and Lucas was kind enough to respond with more information which I hope he won't mind if I will share part of it here for those interested in learning more. Not knowing about this section of the left coast, I was interested in learning more about the site where the picture was taken. Lucas' response: The place we are parked in the picture is the old highway 1 next to theI was also fascinated by the use of the Citroen 2CV (aka: Deux Chevaux) as a toad. We don't see many of those here in the south. The last one I saw belonged to a Belgian fellow I worked with and it had the hydraulic feature that allowed it to lift a wheel for replacement without use of an external jack. Always reminded me of a puppy with a hurt paw! I also wondered if they got 'grief' from old car enthusiasts worried about such a classic car getting dinged up from being towed behind the Bird. Lucas was kind enough to answer my many questions on the toad: <!--[if gte mso 9]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The Deux Chevaux is a 66, it is in very good condition and we use it as a daily driver when we are on the road. It is the perfect "toad" as the car only weighs 1200 pounds. It gets almost 50 miles per gallon. The coach does not even know it is back there. We carry it in on extension like a tow truck with the front wheels of the ground. I have attached a picture of when the carrier was first mounted before the rear bumper went back on. The way I carry it actually allows me to back up as it is the same as a trailer. I lower the carrier attach the bars to hold the wheels, jack the carrier up and pin it. The whole procedure takes 5 minutes. I have plans to add a hydraulic system but for now this works. The color is not original but we do like it. The car has been completely repainted and all the body work redone, we started just redoing the front end and ended up repainting the whole car. We probably should have repainted it in the same color scheme as the coach. The coach has one of those "Whisker" screens below the bumper and other than dirt we have not had a problem with rocks.
<style> st1\:*{behavior:url(#ieooui) } </style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> I hope you enjoyed this added info as much as I did. Many thanks to Lucas and Linda for the additional information. If you would like to share a picture of your Bird and/or an interesting place you found to park a Bird, please send in your photos, with description, for an upcoming Bird of the Week Thanks, Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX |
