bus lights
03-27-2011, 12:09
bus lights
Had a bulb that needed to be replaced at the top of the rear of my 1983 PT 35 WL . When I removed the fixture the wire came loose from a crimp connector inside a small hole only seen one wire which I reconnected and replaced the blub. When I replaced none of the light around the top of the bus would come on. Looked for bad fuse but could not locate. Does anyone know where the fuse is for the lights around the top of the coach and should there have been two wires to each light? Not sure if they are series or parallel wiring. The head lights and all other lights work , but none of the lights at the top of the coach will come on.
Bill
1983 PT 35 WL
PC FL
03-27-2011, 13:12
bus lights
Bill:
The power for the marker lights is in the over head load center a 15 amp
breaker with a green 14 ga. wire number 31.
The marker lights are orig a one wire unit with the ground supplied by one
of the screws holding the body of the light on the Coach.
"84FC35 "Ruff Diamond"
Duncan, Oklahoma
>Bill
>1983 PT 35 WL
>PC FL
03-27-2011, 14:05
bus lights
Thanks so much.
Bill
1983 PT 35 WL
PC FL.
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ralph L. Fullenwider
Sent: Sunday, March 27, 2011 8:13 PM
Subject: Re: [WanderlodgeForum] bus lights
Bill:
Duncan, Oklahoma
>Bill
>1983 PT 35 WL
>PC FL
