Damage revisted again
06-25-2005, 14:07
Some of you may remember that I blew the left tag axle on a recent
trip. It damaged the box holding the shore power plugs etc. I discovered that everything works except the tank fill switch. When I pulled the switch the wires had disappeared. I cannot unscrew the base plate holding the various plugs because the bottom of the box was pushed up and the screws are not visible. I have unscrewed the various plugs to gain access to the wires, but do not seem to be able to find the tank fill wires. Has anyone had their box repaired? I don't seem to be able to remove it. I have pulled up the carpet above it but it looks like there is a floor with a metal base under it. Any suggestion would be helpful. I sent Benny at the factory an emai, but have not had a response. Sid Breese 85PT40 BTW I did John Finn's fix for tail lights and they are very bright. Thanks John! St. Joseph, MO |
