Valve Adjustment, D60, 2000 LXI
04-23-2011, 02:44
Am about to take the coach in for the annual oil & filters replacement; timely
dessicant cartridge changeout. In looking at the recommended maintenance schedule for the D60 I see a valve lash adjustment recommended at 60,000. We're there. Over the phone, the guy from Alamo Diesel wandered if he would go in from the bedroom floor or the rear. Anybody done this on a 2000 LXI? Thanks. 2000 LXI in San Antonio |
04-23-2011, 03:07
04-24-2011, 22:04
--- In WanderlodgeForum@yahoogroups.com, "luckyron1"
> > Am about to take the coach in for the annual oil & filters replacement; timely dessicant cartridge changeout. In looking at the recommended maintenance schedule for the D60 I see a valve lash adjustment recommended at 60,000. We're there. Over the phone, the guy from Alamo Diesel wandered if he would go in from the bedroom floor or the rear. Anybody done this on a 2000 LXI? > Thanks. > > 2000 LXI in San Antonio > UH, oh, doesn't sound like this mechanic knows Bluebirds. Take your coach to Clyde at Seguin Diesel. 830-379-7121, 555 IH 10 East. Clyde owns a BB and knows these Birds. Regards, Liz Pearce 1993 BB WLWB Dhanis, TX SKP |
04-30-2011, 19:23
Thanks for the input folks. As it turned out, they do have to go in thru the
bedroom floor. You have to remove the safe, the carpet, and then the cover and insulation. This allows access for the valve adjustment, a Jake adjustment, and even the ENGINE WATER TEMPERATURE GAUGE SENSOR (also needed on ours) on the 2000 LXI. Alamo Diesel quoted me 860.00 for the valve adjustment including the floor work. Not as bad as what we've heard from some others. We'll have it done next fall. BTW, Alamo Diesel did a nice job on the routine engine maintenance. Oil, filters, chassis lube, brake adjustment, air/dessicant change-out etc. Will be going back for more. 2000 LXI San Antonio, but not for long. --- In WanderlodgeForum@yahoogroups.com, "luckyron1" > > Am about to take the coach in for the annual oil & filters replacement; timely dessicant cartridge changeout. In looking at the recommended maintenance schedule for the D60 I see a valve lash adjustment recommended at 60,000. We're there. Over the phone, the guy from Alamo Diesel wandered if he would go in from the bedroom floor or the rear. Anybody done this on a 2000 LXI? > Thanks. > > 2000 LXI in San Antonio > |
