M380 living room slide
05-06-2011, 13:13
The living room slide on our M380 has decided to stop half way out. It will
retract, but only go out half way. I have checked for obstructions, but haven't found any. I am thinking that maybe if I hit the reset button it will correct itself. Problem is that I can't find the button. I know it is located behind the key switch panel, but don't see anything that looks like a reset button. Has anyone had this problem and can you help me locate the reset switch. Thanks. Jim Mcginnis M380 # 151 |
