buy our wanderlodge and help us launch our new adventure to south america.
07-06-2011, 05:15
We found our 1982 wanderlodge fc35 sb last fall on craigs list and intended to
travel the US. We have been living in it 2 months now but the travel plans have
changed to south america. We can't take the wanderlodge with so we need to find
a good new home for it.
Here are the details.
it has a cat 3208 with about 189000 on it .
I have not seen one drip under it in 9 months.
It has the swing out radiator and an updated grill from a newer unit.
This unit is clean outside and inside and ready to travel.
i think the only thing that needs to be fixed is the leveling jacks. They work
but not quite right.
I have replaced the carpet and drapes and upholstery.
Replaced the bath fan and put in a fantastic fan in the living room.
Installed a new water filter and have a new under sink h2o heater.
I took out the tv tuner and the sub woofer in the bedroom cabinet. (I still
have the tv tuner)
I have moved the central vac to the side of the cabinet to make better use of
the space.
I took out the ice maker and built an under counter pantry pull out in it's
place.
I also remodeled the dinette and removed the back from the bench by the door.
This opens the plan up a lot and makes it easier to pass each other in the
kitchen.
It has the diamond plate roof and luggage rail.
I have a greasecar veggi conversion kit that I have not installed yet if you are
interested.
I also have a 408 watt solar electric system that I have not installed yet. This
could make it self sufficient.
Photos can be seen here. http://gallery.me.com/rlrueter#100072
The photos are before the inside remodel. I'll try to post updated photos soon.
I have it on craigslist to for 24,500
Loading...
