Water check valve problem?
07-07-2011, 00:13
Hello all, I am a new owner of an '83 FC35. I have been going through some of
the systems on the bus, cleaning and learning a lot. After doing searches on
this forum to solve my problem, I still am confused.
The problem I am experiencing is with the water filling and pumping. The water
pump seemed to be working fine until the fresh water tank emptied. I recognized
it was empty right away and filled tank. ( water was coming out of overflow}
Pressure seemed fine for the rest of the evening while using the kitchen sink.
The next day when I tried to use the sink, the pressure from the pump was very
low and no water at all when I turned to the hot water. Pump runs continously. I
disconnected the inlet hose to the Flojet pump thinking maybe airlock-lost
prime, while it was running but that didnt change anything.
Also, I thought I would give a try at using "direct water hookup",(city water),
which gives me hot water and good pressure but it is pouring out the overflow of
fresh water tank while hooked up. Is this where the check valve is bad? What
does it look like? I have the area under the bed open but there are a lot valves
there. I recognize a pressure regulator but this is all new to me. Thanks in
advance for any suggestions or help.
Jeff Lawrence
Panama City Beach,FL.
850-527-1085
07-07-2011, 08:26
Jeff, what you are experiencing is the Sporlan Valve needs a rebuild. This unit has 4 bolts that hold it down. If you back off these bolts a little, there may be some crud in there. Tighten it back up , turn pump on and see if you have pressure. If not, then a rebuild kit from Stephen Birtles is what is needed. His website is dupreeproducts.com
also in the forum database you will find some files about this valve.
88 PT40
817-475-3991
--- On Thu, 7/7/11, jepetto58 wrote:
Subject: [WanderlodgeForum] Water check valve problem?
Date: Thursday, July 7, 2011, 7:13 AM
Hello all, I am a new owner of an '83 FC35. I have been going through some of the systems on the bus, cleaning and learning a lot. After doing searches on this forum to solve my problem, I still am confused.
The problem I am experiencing is with the water filling and pumping. The water pump seemed to be working fine until the fresh water tank emptied. I recognized it was empty right away and filled tank. ( water was coming out of overflow} Pressure seemed fine for the rest of the evening while using the kitchen sink. The next day when I tried to use the sink, the pressure from the pump was very low and no water at all when I turned to the hot water. Pump runs continously. I disconnected the inlet hose to the Flojet pump thinking maybe airlock-lost prime, while it was running but that didnt change anything.
Also, I thought I would give a try at using "direct water hookup",(city water), which gives me hot water and good pressure but it is
pouring out the overflow of fresh water tank while hooked up. Is this where the check valve is bad? What does it look like? I have the area under the bed open but there are a lot valves there. I recognize a pressure regulator but this is all new to me. Thanks in advance for any suggestions or help.
Jeff Lawrence
850-527-1085
07-07-2011, 08:30
Hi jeff:
Switch off the tank fill switch. Though your Sporlan valve may need looking at.
The fill switch controls the coil of the Sporlan valve and that valve is the
diverter valve for coach and shore water. Remember, when you fill your coach
tank, first turn off your pump, it will cycle because it senses the drop in
pressure and tries to run to catch up.
Safe travels, Ralph &
Charolette Fullenwider
'84 FC35 "Ruff Diamond"
Duncan, Oklahoma
Sent via BlackBerry by AT&T
-----Original Message-----
Sender: WanderlodgeForum@yahoogroups.com
Date: Thu, 07 Jul 2011 12:13:40
To:
Reply-To: WanderlodgeForum@yahoogroups.com
Jeff Lawrence
850-527-1085
Yahoo! Groups Links
