fc tachometer
07-24-2011, 05:32
fc tachometer
i have an 87 fc33 which needs a little attention
the tach does not work and i dont have a swingout radiator
does anyone know of an electronic replacement kit or some easier option to
pulling the radiator(cable good so drive bad?)
also my roof leaks also, as per previous post is there an accepted(correct) fix?
thanks for all the forums contributors and there vast knowledge and willingness
to share!!!!!!!!
dana fransen
87 fc33 valley springs ca
07-24-2011, 12:42
fc tachometer
Are you sure there is not a swing-out rad on your 87? I though the swing-out
became standard in 85.
Bob Griesel '84 FC31 WLII WA
fix?
willingness to share!!!!!!!!
> dana fransen
07-24-2011, 22:29
fc tachometer
fix?
> dana fransen
The tach sensor may be on the bell housing near & forward of the tranny,
The Rad does indeed open , Just a little more difficult
because of the air to air cooler.
Loosen the top rad hose from inside the doghouse,
remove grill drop the bumper, and remove the air cooler hose clamps,
remove the driver side park light. a couple bolts behind the light.
