Water inlet pressure regulator for 86 PT40
08-22-2011, 02:48
Hi everybody - Does anybody know where I could get a replacement for the
pressure regulator at the water inlet for our 1986 PT40? I just need the large
threaded piece with the regulator, but will purchase the whole assembly if I
have to in order to get the part.
Thanks!
Greg Young
86 PT40 "Bluefire"
Oceanside CA
08-22-2011, 03:03
Greg
Mine was replaced with the normal type you can buy at RV part stores
Fred & Jeanne Hulse
Morristown,Arizona
97 WLWB41
08-22-2011, 04:11
Greg,
I just went thru this on my 86. Easiest is to replace the all in one backflow preventor/regulator/water fill with a new identical one. I opted not to do that for two reasons. First, I didn't like it being plastic, that's why they crack and go bad. Second,I like to regulate at the faucet, not after the hose. I found a metal backflow/regulator online at tweetys, with separate brass regulator.
Thanks,
Markus
----- Reply message -----
Date: Mon, Aug 22, 2011 10:48 am
Subject: [WanderlodgeForum] Water inlet pressure regulator for 86 PT40
To:
Hi everybody - Does anybody know where I could get a replacement for the pressure regulator at the water inlet for our 1986 PT40? I just need the large threaded piece with the regulator, but will purchase the whole assembly if I have to in order to get the part.
Thanks!
Greg Young
86 PT40 "Bluefire"
Oceanside CA
