engine overheating - cleaning radiator fins
09-03-2011, 04:00
I am having trouble with my engine overheating - had $1,000 worth of work done
and it's still overheating. Someone suggested I have the engine and radiator fins steam cleaned - anybody have this problem? |
09-03-2011, 04:15
Details, details! Year, model, symptoms, work already done?
On 9/3/2011 at 4:00 PM moolah_85224 wrote: >I am having trouble with my engine overheating - had $1,000 worth of work >done and it's still overheating. Someone suggested I have the engine and >radiator fins steam cleaned - anybody have this problem? > > > > >------------------------------------ > >Yahoo! Groups Links > > > |
09-03-2011, 04:47
| engine overheating - cleaning radiator fins | |||
09-03-2011, 08:43
'95 WB 42', checked all the fluid levels, checked water pump, put new
thermostats in and now have had the radiator washed. It's a series 60 Detroit, it doesn't get shut down hot but it will when I hit a mountain. --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > Details, details! Year, model, symptoms, work already done? > > On 9/3/2011 at 4:00 PM moolah_85224 wrote: > > >I am having trouble with my engine overheating - had $1,000 worth of work > >done and it's still overheating. Someone suggested I have the engine and > >radiator fins steam cleaned - anybody have this problem? > > > > > > > > > >------------------------------------ > > > >Yahoo! Groups Links > > > > > > > |
09-03-2011, 09:04
My 97 WB with S60 showed it was over heating but used heat gun and was actually 30 degrees cooler than what the guage showed. Put a sticker under the guage saying -30 and have not worryed about it.
Dick Hardesty Zanesville Ohio Sent from my Droid X On Sep 3, 2011 4:43 PM, "moolah_85224" <"moolah@myway.com"> wrote:
> '95 WB 42', checked all the fluid levels, checked water pump, put new thermostats in and now have had the radiator washed. It's a series 60 Detroit, it doesn't get shut down hot but it will when I hit a mountain. > > > --- In "WanderlodgeForum@yahoogroups.com", "Don Bradner" >> >> Details, details! Year, model, symptoms, work already done? >> >> On 9/3/2011 at 4:00 PM moolah_85224 wrote: >> >> >I am having trouble with my engine overheating - had $1,000 worth of work >> >done and it's still overheating. Someone suggested I have the engine and >> >radiator fins steam cleaned - anybody have this problem? >> > >> > >> > >> > >> >------------------------------------ >> > >> >Yahoo! Groups Links >> > >> > >> > >> > > |
09-04-2011, 12:43
Have you checked the radiator for stoppage internally? Is your cooling fan
coming on correctly? In most cases, the alarmstat fails so that the fan should be on all the time, but you might have some other failure. Another thought: You could have an instrument failure. Check the engine at the water pump with an infra red thermometer. Another problem could be a blown head gasket. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "moolah_85224" <moolah@...> wrote: > > '95 WB 42', checked all the fluid levels, checked water pump, put new thermostats in and now have had the radiator washed. It's a series 60 Detroit, it doesn't get shut down hot but it will when I hit a mountain. > > > --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > > > Details, details! Year, model, symptoms, work already done? > > > > On 9/3/2011 at 4:00 PM moolah_85224 wrote: > > > > >I am having trouble with my engine overheating - had $1,000 worth of work > > >done and it's still overheating. Someone suggested I have the engine and > > >radiator fins steam cleaned - anybody have this problem? > > > > > > > > > > > > > > >------------------------------------ > > > > > >Yahoo! Groups Links > > > > > > > > > > > > |
