Selling My 12.5 Perkins/Kohler Generator.
10-04-2011, 08:05
I'm selling the original 12.5 KW Perkins/Kohler generator in my 83' FC35.
It has under 800 hours on the clock. It leaks no oil. Starts every time. Currently putting out 160 volts and needs a new voltage regulator. There might be some exhaust leak on the flex pipe out of the generator. I replaced the fuel pump and starter in 2008. Also added a Donaldson air filter and new bearing on the fan pulley. Still has most of the original brown paint and no rust. Low hours. I'm about to purchase a newer Onan Quiet Diesel to replace it. My main issue with the old Perkins is noise under the awning! For more info or photos, email me at savethebus@.... Can also send video of it starting and running. The generator is currently in the bus. After you see and hear it run, the buyer will be responsible for removing it. I will help as best I can. Comes with all the components. Just leave me the wires, battery and fuel lines! $995 or best offer! I might even consider selling the stock slide mechanism that the generator sits in. Make an offer. Thanks! Andy Coleman 83' FC35 Jackson, NJ savethebus@... |
