Engine Belts
10-20-2011, 03:18
Engine Belts
I was wandering what the rule of thumb to change your engine belts on a 3208
cat. Whether it be miles or years. what do most of you guys do. I don't want to take off good belts & replace them to soon Thanks for your input. Don Spithaler 89 SP 36' Butler, PA |
10-20-2011, 03:34
Engine Belts
Don
I make it a habit to change drive belts on any vehicle after 5 years,but use the ââ¬Åturn it over and look for cracksââ¬Âat each oil check.
Fred & Jeanne Hulse Morristown,Arizona 97 WLWB41 |
10-20-2011, 05:02
Engine Belts
The 3208 does not seem to be real easy on
belts. I check the tension before any long runs, and open up for a look every year or so, or if I'm in there for other service. I don't think I get more than 3-4 years out of the belts. That's about 15K-20K miles. Because the belts are not that convenient on an FC, any belt I don't like the looks of gets replaced when the front is open. Tension and idler pulleys need to be watched for worn bearings; sloppy bearings lead to premature belt wear and thrown belts. Spare belts and a set of tools are good insurance. Bob Griesel '84 FC31 WLII WA -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of DonS Sent: Thursday, October 20, 2011 8:18 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Engine Belts I was wandering what the rule of thumb to change your engine belts on a 3208 cat. Whether it be miles or years. what do most of you guys do. I don't want to take off good belts & replace them to soon Thanks for your input. Don Spithaler 89 SP 36' Butler, PA ------------------------------------ Yahoo! Groups Links http://groups.yahoo.com/group/WanderlodgeForu m/ http://groups.yahoo.com/group/WanderlodgeForu m/join (Yahoo! ID required) WanderlodgeForum-fullfeatured@yahoogroups.com WanderlodgeForum-unsubscribe@yahoogroups.com |
10-21-2011, 05:16
Engine Belts
I always carry a old set of belts & plenty of tools to do the job. Mine are two years old & I always use the Gates Green Stripe. I guess I'll swing the rad out & check them for cracks as the power steering & compressor belts need tightening. Â Â Â Thanks guys.
Don Spithaler 89 SP 36' Butler, PA On Thu, Oct 20, 2011 at 1:02 PM, BG <"sundance101@comcast.net"> wrote:
