Kohler generator smokes alot!
06-29-2005, 03:31
John, my perkins smokes too. perhaps its the nature of the beast. it also
leaks a little oil- just like my detroit. ernie-83pt40 in montana [Non-text portions of this message have been removed] |
06-29-2005, 04:41
I have the 12.5 Kohler generator in an 85 PT40 it smokes quite alot,
is there anything I can do in minor maintanence? When I start it up it smokes alot then it progressively get less smoke but not all goes away. Oil and filter changed not long ago. John Mann 85 pt40 Granbury Tx. |
06-29-2005, 06:37
--- In WanderlodgeForum@yahoogroups.com, "tracyt3"
> I have the 12.5 Kohler generator in an 85 PT40 it smokes quite alot, > is there anything I can do in minor maintanence? When I start it up it > smokes alot then it progressively get less smoke but not all goes > away. Oil and filter changed not long ago. > > John Mann > 85 pt40 > Granbury Tx. What color smoke, and is it using oil? Jim 82 FC35 |
06-29-2005, 07:52
Try cleaning or replacing the air cleaner.
Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "tracyt3" wrote: > I have the 12.5 Kohler generator in an 85 PT40 it smokes quite alot, > is there anything I can do in minor maintanence? When I start it up it > smokes alot then it progressively get less smoke but not all goes > away. Oil and filter changed not long ago. > > John Mann > 85 pt40 > Granbury Tx. |
06-29-2005, 08:47
Which Detroit is it? What kind of oil are your using in it??
Steve '98 Bluebird QBRE 30' --- In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote: > John, my perkins smokes too. perhaps its the nature of the beast. it also > leaks a little oil- just like my detroit. ernie-83pt40 in montana > > > [Non-text portions of this message have been removed] |
06-29-2005, 08:51
I once overfilled my generator accidentally and the oil got slipped
through and smoked out of the exhaust pipe. Plus side is that it killed a lot of mosquitos! Probably not your problem, but it's worth checking anyway, especially if you didn't service it yourself. Does the smoke smell any certain way? Exhaust? Oil? Does the generator appear to be operating normally or running rough? Possibly your choke? Steve '98 Bluebird QBRE 30' --- In WanderlodgeForum@yahoogroups.com, "pattypape" > > Try cleaning or replacing the air cleaner. > > Bill 88 FC > > --- In WanderlodgeForum@yahoogroups.com, "tracyt3" > wrote: > > I have the 12.5 Kohler generator in an 85 PT40 it smokes quite alot, > > is there anything I can do in minor maintanence? When I start it up > it > > smokes alot then it progressively get less smoke but not all goes > > away. Oil and filter changed not long ago. > > > > John Mann > > 85 pt40 > > Granbury Tx. |
06-29-2005, 09:28
Steve, I use straight 40 weight oil. Ernie-83pt40 in montana
06-29-2005, 09:49
Scott- you mentioned that you knew a fella that was extremely knowledgeable
about exhausts. can you share with us what he told you about your generator exhaust. I have seen quite a few exhausts that were extremely small, thus in my thinking would be restrictive in the performance of that engine. thanks, ernie-83pt40 in montana [Non-text portions of this message have been removed] |
06-29-2005, 13:45
Hey John, Scott here from Murrells Inlet. I would check a couple of
things regarding smoke..mine would leave a big soot mark where I was if I let it run for any length of time... Is there water in the fuel..fuel filter change will tell that What is the size of the exhaust pipe..I just changed mine to 1.75" and made mine better but should have gone to the 2" exhaust diesels gotta breathe. Oil level ok not too full. Injector could be stuck or not working correctly remove and have tested, replaced..a good "tune-up" will check this. John, alot depends on the color of the smoke, blue smoke is oil burnign, black smoke is usually a fuel problem. I will email you the fault guide from the kohler manual fyi..it gives many things to check depending on color of smoke..Hope all is well with you and the family Scott B 86FC35 "Ruby" Murrells Inlet SC --- In WanderlodgeForum@yahoogroups.com, "tracyt3" > I have the 12.5 Kohler generator in an 85 PT40 it smokes quite alot, > is there anything I can do in minor maintanence? When I start it up it > smokes alot then it progressively get less smoke but not all goes > away. Oil and filter changed not long ago. > > John Mann > 85 pt40 > Granbury Tx. |
06-29-2005, 13:47
sorry john your email is private, and we have no members section to
find emails..sheesh...email me cme4boatsataoldot com.. Scott --- In WanderlodgeForum@yahoogroups.com, "tracyt3" > I have the 12.5 Kohler generator in an 85 PT40 it smokes quite alot, > is there anything I can do in minor maintanence? When I start it up it > smokes alot then it progressively get less smoke but not all goes > away. Oil and filter changed not long ago. > > John Mann > 85 pt40 > Granbury Tx. |
