Clearance required
10-25-2011, 07:26
Clearance required
I'm still at it, trying to find a suitable coach that will fit in my warehouse.
Can anyone tell me the clearance height of a BlueBird BMC 37? I realize this is not a BMC forum, but just maybe someone here knows and would tell me. Thanks, Joe Indian Harbour Beach, FL |
10-25-2011, 08:01
Clearance required
Joe You might want to call some of the local metal building guys in your area and see how much they will charge you to put a different height door in your building. Might not be too expensive. Dennis Little RUG and ART Sale Currently Baytown, TX Clearwater, Florida 727.631.3844 dennishlittle@... |
10-25-2011, 08:02
Clearance required
Hi Joe,
What's the clearance height on your warehouse doors? Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX (have to drop the suspension to clear my door frame) --- In WanderlodgeForum@yahoogroups.com, "Joe" > > I'm still at it, trying to find a suitable coach that will fit in my warehouse. > > Can anyone tell me the clearance height of a BlueBird BMC 37? > > I realize this is not a BMC forum, but just maybe someone here knows and would tell me. > > Thanks, > Joe > Indian Harbour Beach, FL > |
10-25-2011, 08:09
Clearance required
Wish I could, but it's a condo warehouse space and the header is poured
concrete. Joe --- In WanderlodgeForum@yahoogroups.com, "Dennis Little" wrote: > > Joe > > > > You might want to call some of the local metal building guys in your area > and see how much they will charge you to put a different height door in your > building. Might not be too expensive. > > > > Dennis Little > > RUG and ART Sale > > Currently Baytown, TX > > Clearwater, Florida > > 727.631.3844 > > dennishlittle@... > |
10-25-2011, 08:10
Clearance required
The door openings are 12 feet, but clearance is a little less than that - maybe
11' 9". Joe --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Hi Joe, > > What's the clearance height on your warehouse doors? > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX (have to drop the suspension to clear my door frame) > > > --- In WanderlodgeForum@yahoogroups.com, "Joe" > > > > I'm still at it, trying to find a suitable coach that will fit in my warehouse. > > > > Can anyone tell me the clearance height of a BlueBird BMC 37? > > > > I realize this is not a BMC forum, but just maybe someone here knows and would tell me. > > > > Thanks, > > Joe > > Indian Harbour Beach, FL > > > |
10-25-2011, 09:10
Clearance required
Joe,
OK. Close call. Now that we know that, I think an FC should be no problem clearing. An SP I'm not sure about. But an added question becomes what is the height of an 80s model PT or SP with the suspension down? I suspect about 11'8" or so. Maybe Bob can measure his for you. In the end result, the only way to be sure before buying is to precisely measure the door opening and the Bird you are interested in with suspension up and down. Too many variables to be sure without actually measuring (Original size tires? Any incline into the door opening? What's added on the roof?, etc.). Is your approach into the doorway level with the interior floor? In my case, I have an incline into my building on the front side. My 83 PT40 cleared my door frame with room to spare, but my 91 has to have the suspension dropped to clear after I get halfway in. Happy hunting. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Joe" > > The door openings are 12 feet, but clearance is a little less than that - maybe 11' 9". > > Joe > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > Hi Joe, > > > > What's the clearance height on your warehouse doors? > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX (have to drop the suspension to clear my door frame) > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Joe" > > > > > > I'm still at it, trying to find a suitable coach that will fit in my warehouse. > > > > > > Can anyone tell me the clearance height of a BlueBird BMC 37? > > > > > > I realize this is not a BMC forum, but just maybe someone here knows and would tell me. > > > > > > Thanks, > > > Joe > > > Indian Harbour Beach, FL > > > > > > |
10-25-2011, 13:36
Clearance required
Well Joe, here is a partial answer: My BMC-37 will fit into my whse with a nominal 12ft door. But the details may not apply to your circumstances...
[I partially backed in while fully aired up with friends watching from several vantage points :-)] Best of luck with your search... Skip On 10/25/2011 03:26 PM, Joe wrote:
10-26-2011, 01:26
Clearance required
Bluebirds seem to be 12 feet, plus or minus. The same model can vary by inches,
depending on tire size , ride height, & stuff on the roof. If you are considering a 12 foot door, some Birds will clear others may not. If a few inches are an issue, dumping the suspension will help lower the height by a few more inches. Several Birds were measured last year at a Rally, there is a chart in post #20. http://www.wanderlodgeownersgroup.com/fo...347&page=2 Bill Pape 1988FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Joe" > > I'm still at it, trying to find a suitable coach that will fit in my warehouse. > > Can anyone tell me the clearance height of a BlueBird BMC 37? > > I realize this is not a BMC forum, but just maybe someone here knows and would tell me. > > Thanks, > Joe > Indian Harbour Beach, FL > |
10-26-2011, 01:32
Clearance required
Depending the type of door and door track mechanism, the door may be able to be
raised higher into the ceiling. Other have lowered the floor especially at the entry point. Bill Pape 1988FC Michigan --- In WanderlodgeForum@yahoogroups.com, billpatty@... wrote: > > > > > Bluebirds seem to be 12 feet, plus or minus. The same model can vary by inches, depending on tire size , ride height, & stuff on the roof. If you are considering a 12 foot door, some Birds will clear others may not. If a few inches are an issue, dumping the suspension will help lower the height by a few more inches. Several Birds were measured last year at a Rally, there is a chart in post #20. > > http://www.wanderlodgeownersgroup.com/fo...347&page=2 > > > Bill Pape 1988FC Michigan > > > --- In WanderlodgeForum@yahoogroups.com, "Joe" > > > > I'm still at it, trying to find a suitable coach that will fit in my warehouse. > > > > Can anyone tell me the clearance height of a BlueBird BMC 37? > > > > I realize this is not a BMC forum, but just maybe someone here knows and would tell me. > > > > Thanks, > > Joe > > Indian Harbour Beach, FL > > > |
10-26-2011, 01:45
Clearance required
Let me thank all of you for the info and insight.
It appears that a FC would be fine and most likely a BMC as I'm also limited in building depth of 37 feet being the absolute maximum I could put inside and still walk (squeeze) around the back of the unit. Thanks again, Joe --- In WanderlodgeForum@yahoogroups.com, billpatty@... wrote: > > Depending the type of door and door track mechanism, the door may be able to be raised higher into the ceiling. Other have lowered the floor especially at the entry point. > > Bill Pape 1988FC Michigan > > --- In WanderlodgeForum@yahoogroups.com, billpatty@ wrote: > > > > > > > > > > Bluebirds seem to be 12 feet, plus or minus. The same model can vary by inches, depending on tire size , ride height, & stuff on the roof. If you are considering a 12 foot door, some Birds will clear others may not. If a few inches are an issue, dumping the suspension will help lower the height by a few more inches. Several Birds were measured last year at a Rally, there is a chart in post #20. > > > > http://www.wanderlodgeownersgroup.com/fo...347&page=2 > > > > > > Bill Pape 1988FC Michigan > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Joe" > > > > > > I'm still at it, trying to find a suitable coach that will fit in my warehouse. > > > > > > Can anyone tell me the clearance height of a BlueBird BMC 37? > > > > > > I realize this is not a BMC forum, but just maybe someone here knows and would tell me. > > > > > > Thanks, > > > Joe > > > Indian Harbour Beach, FL > > > > > > |
