Neutral safty switch
11-04-2011, 08:30
I have a 1985 pt 40 that started one day and the next day I get no sound out of
the starter. I think it may be the neutral safty switch but I can not find it. I looked on the trans and I didn't see dose anyone know where it would be located |
11-04-2011, 09:18
Attached the bottom of the shifter mechanism
Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: "William B" Sender: WanderlodgeForum@yahoogroups.com Date: Fri, 04 Nov 2011 19:30:51 To: Reply-To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Neutral safty switch I have a 1985 pt 40 that started one day and the next day I get no sound out of the starter. I think it may be the neutral safty switch but I can not find it. I looked on the trans and I didn't see dose anyone know where it would be located ------------------------------------ Yahoo! Groups Links |
11-04-2011, 12:17
I have a neutral safety switch for a 85 pt 40 new if I can find it. will advise
. Lee Condosta SOB now. --- In WanderlodgeForum@yahoogroups.com, "William B" > > I have a 1985 pt 40 that started one day and the next day I get no sound out of the starter. I think it may be the neutral safty switch but I can not find it. I looked on the trans and I didn't see dose anyone know where it would be located > |
11-04-2011, 12:26
11-05-2011, 13:06
Got to the neutral salty switch cut the two wires put them together and no start. Anyone no of anything it could be short of the starter. It dose not make a sound so I think its not the starter. Thanks. Bill
Connected by DROID on Verizon Wireless -----Original message-----
11-05-2011, 13:17
Ok Bill, with that out of the equation let's put the switch back into the circuit. Then switch the key to the run position and go open the rear engine compartment. On your right you will find a box with a key switch and a toggle switch. You now need the key for the rear start switch. Insert the kay then toggle the toggle switch to the rear start position and turn the key. The coach should start. If it does we can take the next step and repair what the problem is. If not the we go further in trouble shooting.
Safe travels, Ralph Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T From: "wlb52@..." Date: Sat, 5 Nov 2011 20:06:20 -0400 To: Subject: Re: [WanderlodgeForum] Neutral safty switch Got to the neutral salty switch cut the two wires put them together and no start. Anyone no of anything it could be short of the starter. It dose not make a sound so I think its not the starter. Thanks. Bill
11-05-2011, 13:29
Thanks I will try that tomorrow
11-06-2011, 00:37
11-06-2011, 11:41
On my former coach (1985 PT40) I had your same symptoms a few times caused by two different things. The switch for remote start back in the engine compartment apparently had bad contact points, it would act upoccasionaly and If I flipped it from front to rear and back afew times the coach wouldthen start. I replaced the switch after this happened a couple of times and that eliminated that problem. Another time I had the exact same symptoms, hit the key,it did not crank the engine over and the starter made no noise. That time it turned out to be a jammed (stuck starter), the starter was pulled and the drive gear on the starter was easily freed up and the starter put back on, it never got stuck again.
Good Luck
Wayne Kotila
96PT42
From: "wlb52@..." To: WanderlodgeForum@yahoogroups.com Sent: Saturday, November 5, 2011 7:06 PM Subject: Re: [WanderlodgeForum] Neutral safty switch Got to the neutral salty switch cut the two wires put them together and no start. Anyone no of anything it could be short of the starter. It dose not make a sound so I think its not the starter. Thanks. Bill
11-06-2011, 12:01
I try flipping the toggle switch from front to back four or five times and it didn't start. I'm trying to find the key for the back start spot. Do you think it could be the front key switch
