running my house off coach generator
01-22-2012, 11:14
So our power in Olympia has been off for three days now. Our 88 wb coach is
plugged into the house via a 50 amp hookup at our panel. Is it possible to run the generator in the bus and have it power our house? What would I have to change in order for this to work? ROBERT RAHN Kalispell Mt./Olympia Wa. 1988 pt 40 |
01-22-2012, 11:19
01-22-2012, 11:19
All things are possible. But, without knowing your specific power service distribution I don't think anyone's going to offer a reliable answer to your question. If the commercial power suddenly appears I think that, without protection, your generator will suddenly become an electric motor, albeit briefly.
_________________________________________________________________________________________
In a message dated 1/22/2012 4:14:20 P.M. Mountain Standard Time, chaunceyboyblu@... writes:
01-22-2012, 11:29
01-22-2012, 11:32
Looks like we posted at the same time
--- In WanderlodgeForum@yahoogroups.com, Ernie Ekberg > > If he does it the way I described, it is a reliable answer > > > Ernie Ekberg > 88 PT40 > 817-475-3991 > http://www.ernieekbergflooring.net > > --- On Sun, 1/22/12, PDMcCripe@... > > > From: PDMcCripe@... > To: WanderlodgeForum@yahoogroups.com > Date: Sunday, January 22, 2012, 5:19 PM > > > > Ã > > > > > All things are possible.Ã But, without knowing your specific power service distribution I don't think anyone's going to offer a reliable answer to your question.Ã If the commercial power suddenly appears I think that, without protection, your generator will suddenly become an electric motor, albeit briefly. > ________________________________________________________________________________\ _________ > Ã > > In a message dated 1/22/2012 4:14:20 P.M. Mountain Standard Time, chaunceyboyblu@... writes: > Ã > > So our power in Olympia has been off for three days now. Our 88 wb coach is plugged into the house via a 50 amp hookup at our panel. Is it possible to run the generator in the bus and have it power our house? What would I have to change in order for this to work? > > ROBERT RAHN > Kalispell Mt./Olympia Wa. > 1988 pt 40 > |
01-22-2012, 11:55
We have a manual disconnect so when power returns to our area we can turn the
gen off and not have a problem. I figured there would be some easy way to change the power selector switch in such a way that no cords would be needed since the bus is already plugged into the house. I don't mind changing the bus components in order to do this . Seems like it would be possible. How would I run cords from the bus? Wouldn't cords be very limited in the amount of current available? Im interested in getting all 12.5 kw to the house. Thanks RObert --- In WanderlodgeForum@yahoogroups.com, PDMcCripe@... wrote: > > All things are possible. But, without knowing your specific power service > distribution I don't think anyone's going to offer a reliable answer to > your question. If the commercial power suddenly appears I think that, > without protection, your generator will suddenly become an electric motor, albeit > briefly. > ____________________________________________________________________________ > _____________ > > > In a message dated 1/22/2012 4:14:20 P.M. Mountain Standard Time, > chaunceyboyblu@... writes: > > > > > So our power in Olympia has been off for three days now. Our 88 wb coach is > plugged into the house via a 50 amp hookup at our panel. Is it possible to > run the generator in the bus and have it power our house? What would I > have to change in order for this to work? > > ROBERT RAHN > Kalispell Mt./Olympia Wa. > 1988 pt 40 > |
01-22-2012, 12:01
01-22-2012, 12:18
The quick, simple, and temporary solution is
as Ernie described. For a permanent solution, have a 50 amp receptacle installed in your coach. There may be room in the coach panel for a 220v 50 amp breaker, or you may need a small sub-panel. Then, if it hasn't been done already, have your house panel wired for a generator. Run a cable from the coach's new 50 amp receptacle to the generator connector on your house and you are in business. Bob Griesel '84 FC31 WLII, Olympia WA (currently parked at Q) -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of chaunceyboyblu Sent: Sunday, January 22, 2012 3:14 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] running my house off coach generator So our power in Olympia has been off for three days now. Our 88 wb coach is plugged into the house via a 50 amp hookup at our panel. Is it possible to run the generator in the bus and have it power our house? What would I have to change in order for this to work? ROBERT RAHN Kalispell Mt./Olympia Wa. 1988 pt 40 ------------------------------------ Yahoo! Groups Links http://groups.yahoo.com/group/WanderlodgeForu m/ http://groups.yahoo.com/group/WanderlodgeForu m/join (Yahoo! ID required) WanderlodgeForum-fullfeatured@yahoogroups.com WanderlodgeForum-unsubscribe@yahoogroups.com |
01-22-2012, 12:20
01-22-2012, 12:21
One thing you might check into, is how to hook it up. Here in the Peepoles
Imperal Republik of Kalifornia, you must have a professionally installed main box, (with permits), so you can select EITHER the Power Companys service OR your generator. The object is to prevent "backfeeding" from your generator back out on the power lines. It is a safety measure that will prevent "Zapping" a Lineman working on the line... NOTE: Some of those Linemen are pretty BIG and Nasty...Don't get them mad at you.! ! ! Jack Smith 73FC31 In Sunny&Warm SoCal.. --- In WanderlodgeForum@yahoogroups.com, "chaunceyboyblu" wrote: > > So our power in Olympia has been off for three days now. Our 88 wb coach is plugged into the house via a 50 amp hookup at our panel. Is it possible to run the generator in the bus and have it power our house? What would I have to change in order for this to work? > > > ROBERT RAHN > Kalispell Mt./Olympia Wa. > 1988 pt 40 > |
