Fuse for generator slideout.
02-09-2012, 04:47
I'm removing the generator to replace the main seal. The slide in/out
quit working. Is the punp fuse protected and where is it located?
I know it could still be the micro switch.
Art Weatherly
Riverside Ca
'85 PT36
02-09-2012, 07:22
Art- look in the street side forward storage- where your controls are and on the wall is a couple of fuses. These are not marked, thank you BB, and I believe that one of those controls that.
88 PT40
817-475-3991
--- On Thu, 2/9/12, artw wrote:
Subject: [WanderlodgeForum] Fuse for generator slideout.
Date: Thursday, February 9, 2012, 10:47 AM
Art Weatherly
Riverside Ca
'85 PT36
02-10-2012, 00:04
Art- the circuit is protected with a resetting breaker in the floor of the
generator tray beneath the oil dipstick. Power originates from the hot lead on
the starter, goes to the breaker, then the micro switches on the tray lever/lock
assembly. Then it travels back to a solenoid near the leveling jack pump and
directs hydraulic pressure to the extending ram while the pump is running. I can
email photos of the mechanism if you need them. It's normally hidden by a
protective plate on the front of the genny tray.
Shane Fedeli
85PT40
Hershey, PA
> Art Weatherly
> Riverside Ca
> '85 PT36
02-10-2012, 05:13
Found the ckt bkr yesterday when pulling the engine from the tray.
Lead went to the starter solinoid. I had already removed the battery
cable from the starter - looks like I found the reason for non-operation.
Ernie and Shane thanks for the quick answers.
Art Weatherly
Riverside Ca
'85 PT36
--- In >
02-11-2012, 00:33
Haha- that sounds like one of my "learning experiences"!
> Art Weatherly
> Riverside Ca
> '85 PT36
> --- In >
