Level lights starys on
04-08-2012, 04:32
Hello All,
I have a 1994 40' bus. My problem is the level red light stay on even thought
all the leveling rods are up all the way. Any help would be apreciated on where
to start to fix this problem.
Thanks in advance,
Nelson Slinkman
Westminster, Md
40' wb
04-08-2012, 06:20
Nelson,
Just so I am clear, you mean the red level lights stay on even when the Leveling Master switch is turned to the off position?
1991 WB40 "Texas Minivan"
--- On Sun, 4/8/12, nelsons wrote:
Subject: [WanderlodgeForum] Level lights starys on
Date: Sunday, April 8, 2012, 11:32 AM
Hello All,
I have a 1994 40' bus. My problem is the level red light stay on even thought all the leveling rods are up all the way. Any help would be apreciated on where to start to fix this problem.
Thanks in advance,
Nelson Slinkman
Westminster, Md
40' wb
04-11-2012, 04:55
Hello Mike,
Sorry for he delay in getting back hd to go out of town on business.
The red level lights stays on even when the leveling rods are stored and I can
see that they are all completely up.
Thanks
Nelson
--- In WanderlodgeForum@yahoogroups.com, Michael Bulriss <mbulriss@...> wrote:
> Nelson,
> Mike Bulriss
> San Antonio, TX
> From: nelsons
> Â
> Hello All,
> Thanks in advance,
> Nelson Slinkman
> Westminster, Md
> 40' wb
04-11-2012, 05:46
The way I read Mike's note and yours it sounded to me like you were talking
about different lights. I'm not sure, but probably worth asking the question.
I'm assuming, Nelson, that you are talking about the warning light that says the
jacks are down, while it appeared that Mike was asking about the lights on the
leveling controls. If I am right, the first thing to check is that, with the
jacks fully up, the fluid level in the reservoir is high enough.
On 4/11/2012 at 4:55 PM nelsons wrote:
>Hello Mike,
>can see that they are all completely up.
>Thanks
>Nelson
>wrote:
>> Nelson,
>> Mike Bulriss
>> San Antonio, TX
>> From: nelsons
>> Â
>> Hello All,
>> Thanks in advance,
>> Nelson Slinkman
>> Westminster, Md
>> 40' wb
>Yahoo! Groups Links
04-11-2012, 05:54
There is a magnetic pick up on the jack proper that senses the jack retracted.
If it has not slipped out of place or the wiring is not broken or connectors
corroded, then check the ground in the jack area. The red light should go out
when you turn the jack activation panel off after the jacks are in the store
position or travel position. I would heavily suspect the ground though.
Safe travels, Ralph &
Charolette Fullenwider
'84 FC35 "Ruff Diamond"
Duncan, Oklahoma
Sent via BlackBerry by AT&T
-----Original Message-----
Sender: WanderlodgeForum@yahoogroups.com
Date: Wed, 11 Apr 2012 16:55:54
To:
Reply-To: WanderlodgeForum@yahoogroups.com
Subject: [WanderlodgeForum] Re: Level lights starys on
Hello Mike,
Thanks
Nelson
> Nelson,
> Mike Bulriss
> San Antonio, TX
> From: nelsons
> Â
> Hello All,
> Thanks in advance,
> Nelson Slinkman
> Westminster, Md
> 40' wb
Yahoo! Groups Links
04-11-2012, 06:42
Thanks Ralph,
I will check to see if there is a magnet closing the reed switch. Do you know
where the leveling module is located under the coach?
Thanks Again,
Nelson
> Duncan, Oklahoma
> From: "nelsons"
> To:
> Hello Mike,
> Thanks
> Nelson
> --- In WanderlodgeForum@yahoogroups.com, Michael Bulriss <mbulriss@> wrote:
> > Nelson,
> > Mike Bulriss
> > San Antonio, TX
> > From: nelsons
> > Â
> > Hello All,
> > Thanks in advance,
> > Nelson Slinkman
> > Westminster, Md
> > 40' wb
> Yahoo! Groups Links
04-11-2012, 06:46
Your module should be center just back of the front tires, give or take.
Duncan, Oklahoma
Date: Wed, 11 Apr 2012 18:42:56
To:
Thanks Ralph,
Thanks Again,
Nelson
> Duncan, Oklahoma
> From: "nelsons"
> To:
> Hello Mike,
> Thanks
> Nelson
> > Nelson,
> > Mike Bulriss
> > San Antonio, TX
> > From: nelsons
> > Â
> > Hello All,
> > Thanks in advance,
> > Nelson Slinkman
> > Westminster, Md
> > 40' wb
> Yahoo! Groups Links
Yahoo! Groups Links
04-11-2012, 08:20
Thanks for the info Ralph.
> Duncan, Oklahoma
> From: "nelsons"
> To:
> Thanks Ralph,
> Thanks Again,
> Nelson
retracted. If it has not slipped out of place or the wiring is not broken or
connectors corroded, then check the ground in the jack area. The red light
should go out when you turn the jack activation panel off after the jacks are in
the store position or travel position. I would heavily suspect the ground
though.
> > Duncan, Oklahoma
> > From: "nelsons"
> > To:
> > Hello Mike,
> > Thanks
> > Nelson
> > > Nelson,
> > > Mike Bulriss
> > > San Antonio, TX
> > > From: nelsons
> > > Â
> > > Hello All,
> > > Thanks in advance,
> > > Nelson Slinkman
> > > Westminster, Md
> > > 40' wb
> > Yahoo! Groups Links
> Yahoo! Groups Links
