Demise of ECM Unit, 2000 LXI
04-30-2012, 11:04
A few days ago, while having some routine maintenance done at Freightliner of
San Antonio, (formerly Alamo Motorcoach) the Brake Lites spontaneously came on
and stayed on; and also some of the dash instrumentation went out at the same
time; and the only way to put out the brake lites was to pull the fuse in the
outside panel. Shortly thereafter, , the coach wouldn't start. Further
diagnostics determined that the original ECM unit had seen it's better days and
so it was replaced and now it starts and runs normal and of course the brake
lites and dash gauges are now functioning normally. This is a 12 yr. old coach
so I would guess that this was not unusual. We are just so happy that it didn't
happen on the road. The joys of full-timing.
In Nacogdoches for the nite
04-30-2012, 11:11
Always something to come up~
88 PT40 Wanderlodge
Weatherford, Texas
817-475-3991
--- On Mon, 4/30/12, luckyron1 wrote:
Subject: [WanderlodgeForum] Demise of ECM Unit, 2000 LXI
Date: Monday, April 30, 2012, 6:04 PM
A few days ago, while having some routine maintenance done at Freightliner of San Antonio, (formerly Alamo Motorcoach) the Brake Lites spontaneously came on and stayed on; and also some of the dash instrumentation went out at the same time; and the only way to put out the brake lites was to pull the fuse in the outside panel. Shortly thereafter, , the coach wouldn't start. Further diagnostics determined that the original ECM unit had seen it's better days and so it was replaced and now it starts and runs normal and of course the brake lites and dash gauges are now functioning normally. This is a 12 yr. old coach so I would guess that this was not unusual. We are just so happy that it didn't happen on the road. The joys of full-timing.
