Screen Room for a '93 Bird
06-25-2012, 01:01
Hi....New owner here. My partner and I are looking at screen rooms that attach
on the side of a coach. Any suggestions? Also,wondering if a solution like Liquid Plumber is ok to use in the shower drain. Thank you so much. Zoey Bolduc |
06-25-2012, 05:34
Zoey,probably no liquid plumber since its VERY caustic and would probably destroy your plumbing and holding tank. Simple green or some not toxic cleaner to put down into tank and wash it as you ride. If shower is stopped up, take drain cap off and run drain snake to open up. Happy camping p.s. you need to sign on with your name, year and model of Bird and home location; just protocol
![]() Wallace & Faye Craig
95 WLWB 42
Azle, Texas
06-25-2012, 13:03
Hello Zoey: Wallace gave good advice on the drain, it is pretty straight
forward really, close the bath fill port then fill the tub area with a few inches of water and ready a plunger then open the drain and use the plunger lifting the cup to insert more water then forcing it down. As to the screen room, Google Zip Dee and look at their add on section. Congrats on your Bird. Oh and check the sig lines, (smile) Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma 2005 Jeep Wrangler X _______ /l ,[____], l---L -OlllllllO- ()_) ()_)--o-)_) At 01:01 PM 6/25/2012 +0000, you wrote: >Hi....New owner here. My partner and I are looking at screen rooms that >attach on the side of a coach. Any suggestions? Also,wondering if a >solution like Liquid Plumber is ok to use in the shower drain. Thank you >so much. >Zoey Bolduc > > > > |
