8V92 Temp
07-02-2005, 04:29
8V92 Temp
I just bought an'88 WB PT40 in Louisiana and drove it home to Alaska
last month. For the first half of the trip the temp was rock solid at
about 180. Halfway through the trip the temp started to constantly
climb to 195 where the fan would come on and cool it back to 180. It
does this all the time now whether we are in the hills or on the
flats. I have had the thermostats and water pump changed and it still
does it. I don't think there is any danger because it never gets
above 195. Do any of you see your temps regularly climb to 195 and
then back to 180 as a constant cycle?
Mark Johnson
Wasilla, AK
'88 WLWB PT40
07-02-2005, 04:35
8V92 Temp
my 93 does that.i run my fan most of the time,just to keep it the same temp.
randy
Sent: Saturday, July 02, 2005 12:29 PM
Subject: [WanderlodgeForum] 8V92 Temp
Mark Johnson
Wasilla, AK
'88 WLWB PT40
YAHOO! GROUPS LINKS
07-02-2005, 04:39
8V92 Temp
Randy,
That's a good idea. The fan comes on a little late
for my liking in my FC, too. I've got a switch and usually
control the temp myself.
If you want to be sure of temperatures, use a laser
infrared temperature gun near the coolant sensor to see how
accurate the gauge is.
George Witt
81 FC 35
Lincoln, Nebraska
same temp. randy
> From: Mark Johnson
solid at
still
> Mark Johnson
> Wasilla, AK
> '88 WLWB PT40
> YAHOO! GROUPS LINKS
Service.
07-02-2005, 05:15
8V92 Temp
Mark: Your cooling system is working just as it's advertised to do so.
It's in a constant cycle of heat up cool down. The fan take's
(according to BB) 60hp. to operate. The cleaner you keep your cooling
system the fewer time's it has to cycle and the better your mpg will
be. Don't worry about the fan cycling it's built to do that and won't
hurt a thing. It sounds like healthy system. Bob 93pt illinois
