1982 PT40 Air Compression
10-22-2012, 11:01
Hello Gracious BlueBird Owners,
I appreciate any help you can give me. Have a 1982 Wanderlodge PT40. It has been sitting for 4 years. Have a buyer who came form Texas. He installed new batteries and she fired right up. The problem: the air compression didn't kick in. It was working perfectly when parked. A portable air compressor was connected to the rear line and the rears and tag lifted but not the front end. The new buyers were baffled and not familiar enought to solve this and time frames forced them back to Texas and the Bird still sits in Fresno. By the way while sitting the batteries had been disconnected but the coach was used by direct electrical hook up for lights and electric only in the coach. Maybe a relay or switch or valve has failed. I can't advise these buyer/mechanics. Please I need your feedback. I understand Randy Dupree and Ralph Fullenwider are the main experts and I would more than welcome any of your feedback for my buyer. Anyone else that has good or creative thought please contact me so I can connect you to Herman the buyer so he can bring his new bird home to Texas. I greatly appreciate any help you Wanderlodge wizards have. Thank You. Jerry LeGris 888-441-8751 jerrylegris@... |
10-23-2012, 02:45
Well, it was the main air line from the compressor to the dryer what busted on
my 1985 PT40. Not amenable to field replacement, since the compressor is on top of the Detroit and the line runs behind the engine. So the compressor is now rebuilt, a newly fabricated line is in place and all other air lines have been chased/tested; she airs up in 5 minutes now. [The original symptom was variable airing time, until she refused to air up at all.] Best case scenario, the cruise control will also work now.... Fresno, California - Fresno Texas is 15 miles from me, wish I could refer you to my shop. Me, I realized all along that I was setting myself up to deal with 27-year-old rubber... -Debbie Huffman 1985 PT 40 "Festina Lente" --- In WanderlodgeForum@yahoogroups.com, "legrisjerry" > > Hello Gracious BlueBird Owners, > I appreciate any help you can give me. Have a 1982 Wanderlodge PT40. It has been sitting for 4 years. Have a buyer who came form Texas. He installed new batteries and she fired right up. The problem: the air compression didn't kick in. It was working perfectly when parked. A portable air compressor was connected to the rear line and the rears and tag lifted but not the front end. > The new buyers were baffled and not familiar enought to solve this and time frames forced them back to Texas and the Bird still sits in Fresno. > By the way while sitting the batteries had been disconnected but the coach was used by direct electrical hook up for lights and electric only in the coach. Maybe a relay or switch or valve has failed. I can't advise these buyer/mechanics. Please I need your feedback. > I understand Randy Dupree and Ralph Fullenwider are the main experts and I would more than welcome any of your feedback for my buyer. > Anyone else that has good or creative thought please contact me so I can connect you to Herman the buyer so he can bring his new bird home to Texas. > I greatly appreciate any help you Wanderlodge wizards have. > Thank You. > Jerry LeGris > 888-441-8751 > jerrylegris@... > |
10-23-2012, 14:04
When I had my air compressor replaced the mechanic stated that many times the air hoses from the compressor go bad and leak. Thanks, Jim Riordan
On Oct 22, 2012, at 7:01 PM, "legrisjerry" <"jerrylegris@gmail.com"> wrote:
10-24-2012, 12:54
Hi Jim,
Thanks so much for your feed back. I will forward it to Herman. He is headed back this weekend to get her going again. JerryÂ
On Tue, Oct 23, 2012 at 7:04 PM, James Q Riordan Jr <"jqrjr@yahoo.com"> wrote:
Jerry LeGris, Broker Associate
Commercial & Residential
DRE # 00885785
Prudential Calif Realty
3728 Atlantic Ave.
Long Beach, CA 90807
Cell: 949 510-2370
Office: 562 989-4608
Fax: 562 989-4803
email: "jerrylegris@gmail.com"
Â
10-24-2012, 12:58
Hi Debbie,
Thanks so much for your feed back. I will pass it on to Herman. Jerry
DRE # 00885785
3728 Atlantic Ave.
Cell: 949 510-2370
Fax: 562 989-4803
Â
10-24-2012, 14:05
You can get his and fittings that can be made up in the field. You should be able to get to the top hose from the right side of engine. When they replaced my compressor they had to do it from under the coach. The compressor was a smaller one than dd lists as the correct one it is shorter. Thanks, Jim Riordan
On Oct 24, 2012, at 8:54 PM, Jerry LeGris <"jerrylegris@gmail.com"> wrote:
10-24-2012, 14:09
Hose not his Thanks, Jim Riordan
10-25-2012, 05:10
Hi Jerry,
First off, I guess congrats on selling the bus in this market. I have been watching this thread with interest. Just out of curiosity, did your buyer, Herman, used to have a BB here in Texas several years ago? Although you have gotten some good inputs, a few things seem to me that there may be multiple problems here. Especially after sitting for four years. I suppose it could be the air pump hose, as several people noted, or the air pump itself, or the air governor even. Although you stated that when you put an air compressor on the rear Schrader valve only the rears lifted and not the front. That implies a separate and different problem altogether in my mind. After four years of sitting, if the air dryer was not working correctly upon storage, there could be condensation problems in the entire air system that 'gummed up' some of the air controlled valves in the system - including the brake system, which does not seem to have been exercised yet. You said "The new buyers were baffled and not familiar enough to solve this". Given that they seem to have limited knowledge and limited time, and probably aren't able to bring lots of tools, heavy jack stands, etc. with them, I would be looking for a diesel repair service that does road calls to meet them at the bus when they arrive. Those road service guys see similar problems all the time, so they can diagnose and repair faster than someone without knowledge and proper tools, and importantly, they know where all the local parts houses and repair facilities are that can make hoses, etc. It seems like on most of my repairs, I spend more time finding the proper parts than I do on the actual repair. BTW, since this seems like there are air system problems, I would also want the service guy present when I tried the brakes for the first time. I guess where I come down on this is I try to do most of my own maintenance if I can, but if it was me, given time, distance, unfamiliar locale and the need to get moving, there is no question in my mind that I would be lining up a local roadside diesel repair service to meet me when I arrived. The buyers can be concentrating on checking tires, fluids and provisioning the bus for the trip while repairs are taking place. Speaking of tires, before setting out cross country, that's a place I would be concerned with after four years of sitting. Were they covered or otherwise out of the sun and parked on plastic or wood, between them and the concrete? Anyway, good luck to you and your buyer and please let us know the end result so we can all learn from this. FWIW, Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "legrisjerry" > > Hello Gracious BlueBird Owners, > I appreciate any help you can give me. Have a 1982 Wanderlodge PT40. It has been sitting for 4 years. Have a buyer who came form Texas. He installed new batteries and she fired right up. The problem: the air compression didn't kick in. It was working perfectly when parked. A portable air compressor was connected to the rear line and the rears and tag lifted but not the front end. > The new buyers were baffled and not familiar enought to solve this and time frames forced them back to Texas and the Bird still sits in Fresno. > By the way while sitting the batteries had been disconnected but the coach was used by direct electrical hook up for lights and electric only in the coach. Maybe a relay or switch or valve has failed. I can't advise these buyer/mechanics. Please I need your feedback. > I understand Randy Dupree and Ralph Fullenwider are the main experts and I would more than welcome any of your feedback for my buyer. > Anyone else that has good or creative thought please contact me so I can connect you to Herman the buyer so he can bring his new bird home to Texas. > I greatly appreciate any help you Wanderlodge wizards have. > Thank You. > Jerry LeGris > 888-441-8751 > jerrylegris@... > |
10-25-2012, 09:39
HI Jerry,
Hope this works out for you ;} I had a problem with my '87 PT in Bakersfield one time and used Valley Power Systems. http://valleypowersystems.com/ The 'do not shift' light on the trans panel came on and stuck me. At the shop they had 2 guys work on it for an hour. Didnt find anything, but didnt charge me either!! YMMV... /Joe '87 PT 40 Alligator Sedona, AZ. On Mon, Oct 22, 2012 at 4:01 PM, legrisjerry <"jerrylegris@gmail.com"> wrote:
10-26-2012, 04:50
Did you get your problem figured out yet? The rear of the bus airing up and not
the front may be a seperate problem. This sounds like a problem with the level control valves, there are two in the rear that control the amount of air distribution pressure to the air bags on left and right side of the bus and there is one in the front that controls the air distribution pressure between the front and rear air bags. If one of these valves fails the air bags on one side or one end of the bus may not inflate. Wayne Kotila Buffalo, MN 1996 PT42 --- In WanderlodgeForum@yahoogroups.com, "legrisjerry" > > Hello Gracious BlueBird Owners, > I appreciate any help you can give me. Have a 1982 Wanderlodge PT40. It has been sitting for 4 years. Have a buyer who came form Texas. He installed new batteries and she fired right up. The problem: the air compression didn't kick in. It was working perfectly when parked. A portable air compressor was connected to the rear line and the rears and tag lifted but not the front end. > The new buyers were baffled and not familiar enought to solve this and time frames forced them back to Texas and the Bird still sits in Fresno. > By the way while sitting the batteries had been disconnected but the coach was used by direct electrical hook up for lights and electric only in the coach. Maybe a relay or switch or valve has failed. I can't advise these buyer/mechanics. Please I need your feedback. > I understand Randy Dupree and Ralph Fullenwider are the main experts and I would more than welcome any of your feedback for my buyer. > Anyone else that has good or creative thought please contact me so I can connect you to Herman the buyer so he can bring his new bird home to Texas. > I greatly appreciate any help you Wanderlodge wizards have. > Thank You. > Jerry LeGris > 888-441-8751 > jerrylegris@... > |
