Sluggish 8V92
11-07-2012, 07:43
Sluggish 8V92
I have a "1991 Bluebird Wanderlodge WB40" with a silver "8V92".
Lately it has become painfully slow at accelerating from a dead stop. It is
getting to the point of being unsafe to attempt to merge into traffic.
Once you get it rolling down the highway, it isn't so bad...I have no problems
maintaining 70mph.
Turbo boost will show a bit over 20 for a max, but when accelerating from a
stop, boost is less then 10, and the rpm's just don't want to rev up.
When it is first started, when cold, it does not sound as smooth as I thought it
used to.....almost like it has a slight mis. Seems to smooth out once it is
warm.
Bought it used with 160,000 miles, it now has a bit over 200,000 miles. The fuel
and air filters have been recently serviced, but I have no knowledge of any past
maintenance history.....so I don't know if there are other issues that need to
be looked at....ie: valve settings, fuel injectors, etc.
Has anyone else had this issue, or have any ideas at what I may need to check to
help resolve this problem?
Thanks, Jerry
11-07-2012, 07:46
Sluggish 8V92
Were primary and secondary fuel filters both replaced ? I'd take both of them out and see if they are dirty.
Thanks,
Markus
-----Original Message-----
Sent: 7 Nov 2012 19:43:49 GMT
Subject: [WanderlodgeForum] Sluggish 8V92
Lately it has become painfully slow at accelerating from a dead stop. It is getting to the point of being unsafe to attempt to merge into traffic.
Once you get it rolling down the highway, it isn't so bad...I have no problems maintaining 70mph.
Turbo boost will show a bit over 20 for a max, but when accelerating from a stop, boost is less then 10, and the rpm's just don't want to rev up.
When it is first started, when cold, it does not sound as smooth as I thought it used to.....almost like it has a slight mis. Seems to smooth out once it is warm.
Bought it used with 160,000 miles, it now has a bit over 200,000 miles. The fuel and air filters have been recently serviced, but I have no knowledge of any past maintenance history.....so I don't know if there are other issues that need to be looked at....ie:
Has anyone else had this issue, or have any ideas at what I may need to check to help resolve this problem?
Thanks, Jerry
11-07-2012, 07:55
Sluggish 8V92
Without feeling it, it is hard to say. The 8V92 is an engine that has to rev
high before you get any torque going, so it is always slow off the line.
Just as described I would say that mine is the same, and is normal. That
includes turbo values. The only thing that is a question mark is your use of
"Lately" which implies that it didn't used to be that way.
Don Bradner
90 PT40 "Blue Thunder"
>other issues that need to be looked at....ie: valve settings, fuel
>injectors, etc.
>Thanks, Jerry
>Yahoo! Groups Links
11-07-2012, 08:05
Sluggish 8V92
Hi Jerry,
You mentioned the fuel filters have been recently serviced. Is that about the
time or shortly there after that your rough idle started? If it were me I would
start simply and economically by changing out the fuel filters again. Does your
Racor gauge show alot of restriction? Try that and see how you make out. At 200K
you are probably due for a valve adjustment and other tune up items.
Try the filters first. You may have one that is allowing a very slight amount of
air into the fuel system or an o ring not quite seated on your Racor.
Cheers
Gary
maintaining 70mph.
warm.
to be looked at....ie: valve settings, fuel injectors, etc.
> Thanks, Jerry
11-07-2012, 12:47
Sluggish 8V92
Jerry
What temperature is cold? Mine does
not like temps much under 50 to start smoothly. I would also start with
the filters then to the valve adjustment. Had a valve adjustment done on
mine two years ago, lots of difference.
Steve Quandt
1993 PT-40
Iron Mountain, MI
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Jerry
Sent: Wednesday, November 07, 2012
1:44 PM
Sluggish 8V92
maintaining 70mph.
warm.
need to be looked at....ie: valve settings, fuel injectors, etc.
Thanks, Jerry
11-07-2012, 12:50
Sluggish 8V92
Steve- are you in Marble Falls? I looked at the river cg and didn't see anything but white trailers
88 PT40 Wanderlodge
Weatherford, Texas
817-475-3991
Sent: Wednesday, November 7, 2012 6:47 PM
Subject: RE: [WanderlodgeForum] Sluggish 8V92
Jerry
Steve Quandt
1993 PT-40
Iron Mountain, MI
From: WanderlodgeForum@yahoogroups.com [mailto: WanderlodgeForum@yahoogroups.com ] On Behalf Of Jerry
1:44 PM
Sluggish 8V92
maintaining 70mph.
warm.
Thanks, Jerry
11-07-2012, 23:00
Sluggish 8V92
I would change out my RACOR filter first, Then if it is still sluggish check your air filter. Simple cheap things first
Rob, Sue and Joey Robinson
11-08-2012, 00:57
Sluggish 8V92
Ernie
We are at Sunset Point.
Steve
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ernie Ekberg
6:51 PM
Subject: Re: [WanderlodgeForum]
Sluggish 8V92
Steve- are
88 PT40
Wanderlodge
Weatherford, Texas
817-475-3991
6:47 PM
Sluggish 8V92
Jerry
What temperature is
cold? Mine does not like temps much under 50 to start smoothly. I
would also start with the filters then to the valve adjustment. Had a
valve adjustment done on mine two years ago, lots of difference.
Steve Quandt
1993 PT-40
Iron Mountain, MI
1:44 PM
Sluggish 8V92
I have a
maintaining 70mph.
warm.
Thanks, Jerry
11-08-2012, 03:19
Sluggish 8V92
Thanks for all the quick replies.
Have checked the filters and exhaust, they look okay. (Changed the final fuel
filter, cut the old one apart.) Recently changed the fuel/water separator,
gauge still shows it to be good. Plan on checking the fuel pressure today.
If I don't find anything obvious, I will have the valves and injectors looked
at.
I know these things don't jump off the line, but this thing is really getting
bad. There is just so little throttle response when accelerating from a dead
stop.
In response to how cold when doing cold starts....doesn't seem to matter if its
summer or winter.....here in Georgia, we're talking 60's down to 30's.
Thanks again, and if and when we find out the problem, I'll report back.
maintaining 70mph.
warm.
> Thanks, Jerry
11-08-2012, 05:46
Sluggish 8V92
hope you have a ggod stay. I was driving thru last week on my way to a quick look see on a job in San A
88 PT40 Wanderlodge
Weatherford, Texas
817-475-3991
Sent: Thursday, November 8, 2012 6:57 AM
Ernie
Steve
From: WanderlodgeForum@yahoogroups.com [mailto: WanderlodgeForum@yahoogroups.com ] On Behalf Of Ernie Ekberg
6:51 PM
Sluggish 8V92
Steve- are
you in Marble Falls ? I looked at the river cg and
88 PT40
Wanderlodge
Weatherford, Texas
817-475-3991
6:47 PM
Sluggish 8V92
Jerry
What temperature is
Steve Quandt
1993 PT-40
Iron Mountain, MI
1:44 PM
Sluggish 8V92
I have a
maintaining 70mph.
warm.
Thanks, Jerry
